Problem with Debug Session  Code=0x80047344
Question asked by ibotopal on May 29, 2015
Latest reply on Aug 11, 2015 by ibotopal
I'm working on a custom board with ADSP-21469. I'm using CCES 1.1 under windows 7 with HPUSB. Until yesterday my setup was ok, but suddenly I started to get the mentioned problem although JTAG ICE Test under configurator seems to work. I tried changing the boards, changing USB ports, power supply etc. but nothing worked. JTAG adapter seems to be OK as I was able to connect to an evaluation board.
Could you give me some hints for solving this problem.
Console Output:
ERROR: JTAG scan failed - Check target power and emulator connection. ()
ERROR: DSP could not generate emulator interrupt ()
ERROR: Emulator HW could not scan EMUSTAT register. ()
ERROR: DSP could not scan NOP into EMUPMD ()
ERROR: Failed first NOP block scan. ()
ERROR: Failed second NOP block scan. ()
ERROR: DSP could not clear EMUPMD ()
Loading application: "C:\Projects\CrossCore\Test\Sample_SPORT_Ch_Loop\Release\Sample_SPORT_Ch_Loop.dxe"
ERROR: Cannot load memory while target is running. ()
Error loading section "dxe_iv_code" to target.
