ADXL362 not functional?
Question asked by MEK on May 23, 2015
Latest reply on May 25, 2015 by neilzhao
Hi All,
After setting up my sparkfun breakboard-mounted ADXL362, and having seen g's about 1.3 while still, I decided to run the self-test on it.
I am not too experienced with programming these babies, so please point me to any noob's mistake I might be running into.
I followed the instructions in the datasheet and set it up with precision +/-8g's, 100Hz, normal operation (no noise reduction) and no anti-aliasing. It runs on under 3v on an nRF51 DK board.
I executed this method:
void do_self_test()
  uint32_t err_code;
  uint8_t inBuffer[8];//first two are padding, rest if for 6 uint's
  uint8_t regIn;
Self-Test Output Change
  Min Typ Max
XOUT 230 550 870 mg
YOUT -870 -550 -230 mg
ZOUT 270 535 800 mg
  SEGGER_RTT_printf(0, "\r\nSelf testing...\r\n", regIn);
  nrf_delay_ms( 1000 );
  MK_SPI_ReadRegs( MK_ACC_REG_XDATA_L, 6, inBuffer );
  fifo_in_good[0].x = processPairOfUints12BitsSigned( inBuffer[2], inBuffer[3] );
  fifo_in_good[0].y = processPairOfUints12BitsSigned( inBuffer[4], inBuffer[5] );
  fifo_in_good[0].z = processPairOfUints12BitsSigned( inBuffer[6], inBuffer[7] );
  int16_t xG = fifo_in_good[0].x;
  int16_t yG = fifo_in_good[0].y;
  int16_t zG = fifo_in_good[0].z;
  xG *= 4;//to mg's
  yG *= 4;//to mg's
  zG *= 4;//to mg's
  SEGGER_RTT_printf(0, "Original = %03x %03x %03x = %04d %04d %04d; mG = (%d, %d, %d)\r\n",
  fifo_in_good[0].x, fifo_in_good[0].y, fifo_in_good[0].z,
  xG, yG, zG );
  MK_SPI_WriteReg( MK_ACC_REG_SELF_TEST, 0xFF );
  // wait 4/ODR
  nrf_delay_ms( 40 );
  int16_t xGacc = 0;
  int16_t yGacc = 0;
  int16_t zGacc = 0;
  for(int i= 0; i < 8; i ++)
  int16_t xGaux = fifo_in_good[0].x;
  int16_t yGaux = fifo_in_good[0].y;
  int16_t zGaux = fifo_in_good[0].z;
  xGaux *= 4;
  yGaux *= 4;
  zGaux *= 4;
  SEGGER_RTT_printf(0, "Reading %d = %03x %03x %03x = %04d %04d %04d; mG = (%d, %d, %d)\r\n", i+1,
  xGaux, yGaux, zGaux );
  xGacc += xGaux;
  yGacc += yGaux;
  zGacc += zGaux;
  // Div by 8
  xGacc /= 8;
  yGacc /= 8;
  zGacc /= 8;
  SEGGER_RTT_printf(0, "Final mG = (%d, %d, %d)\r\n", xGacc, yGacc, zGacc );
  SEGGER_RTT_printf(0, "Delta mG = (%d, %d, %d)\r\n", xGacc - xG, yGacc - yG, zGacc - zG );
  SEGGER_RTT_WriteString(0, "Done!\n" );
  MK_SPI_WriteReg( MK_ACC_REG_SELF_TEST, 0x00 );
  while( true );
Running it results in the following output (please don't mind the console's bug when formatting ints as hex):
Resetting device...
Read ID0 + 3 = 0xFFFFFFAD, 0x1D, 0xFFFFFFF2, 0x02.
FIFO_CTL = 0x0A, FIFO_SAM = 0xFFFFFFFF
FILTER_CTL = 0x83
POWER_CTL = 0x02
Self testing...
Original = 01F 018 153 = 0031 0024 0339; mG = (124, 96, 1356)
Reading 1 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Reading 2 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Reading 3 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Reading 4 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Reading 5 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Reading 6 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Reading 7 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Reading 8 = 143 FFFFFEE3 258 = 0323 -285 0600; mG = (1292, -1140, 2400)
Final mG = (1292, -1140, 2400)
Delta mG = (1168, -1236, 1044)
According to the datasheet, the delta in mg's is way off (by about a factor of 2). Does this mean my 362 is out of combat? or am I doing something wrong in the test procedure?
Thanks in advance for any clues you may provide me with.
M.
