AD9984A wrong output
Question asked by staringlizard on May 19, 2015
Latest reply on May 29, 2015 by mattp
Hi EZ !
I had a board made which is utilizing this device. I use VGA as input with 1280x720 @ 60Hz (I have tried some other format with same problem). I use the scripts that you have supplied (see below in this post).
The device works in the meaning that it is outputting data, HS, VS etc. But I am not getting correct output.
For blue channel (for example), no matter what I am feeding into the blue input analog pin (BAIN0, see picture analog_blue_rgb_signal.bmp), I will always get:
blue 0 = 1
blue 1 = 0
blue 2 = data (toggles)
blue 3 = 0
blue 4 = 1
blue 5 = 0
blue 6 = 0
blue 7 = 0
blue 8 = 0
blue 9 = 1
On the other side I will get something like the attached picture (keep in mind that the picture is taken after FPGA and frame buffer) (picture.jpg). I just get some purple dots (flickering back and forth) on a purple background.
Could the device be broken somehow? Is there something I am missing here ?
In my world, either the device is working or it is broken. But this is different. I can talk I2C with the device, change settings, get output from it etc. without problem.
/StaringL
<devicevalues name="AD9984">
  <registerval addr="0" value="17"/>
  <registerval addr="1" value="103"/>
  <registerval addr="2" value="32"/>
  <registerval addr="3" value="168"/>
  <registerval addr="4" value="128"/>
  <registerval addr="5" value="64"/>
  <registerval addr="6" value="0"/>
  <registerval addr="7" value="64"/>
  <registerval addr="8" value="0"/>
  <registerval addr="9" value="64"/>
  <registerval addr="A" value="0"/>
  <registerval addr="B" value="64"/>
  <registerval addr="C" value="0"/>
  <registerval addr="D" value="0"/>
  <registerval addr="E" value="32"/>
  <registerval addr="F" value="64"/>
  <registerval addr="10" value="0"/>
  <registerval addr="11" value="32"/>
  <registerval addr="12" value="0"/>
  <registerval addr="13" value="32"/>
  <registerval addr="14" value="4"/>
  <registerval addr="15" value="10"/>
  <registerval addr="16" value="4"/>
  <registerval addr="17" value="4"/>
  <registerval addr="18" value="10"/>
  <registerval addr="19" value="40"/>
  <registerval addr="1A" value="20"/>
  <registerval addr="1B" value="51"/>
  <registerval addr="1C" value="255"/>
  <registerval addr="1D" value="120"/>
  <registerval addr="1E" value="52"/>
  <registerval addr="1F" value="146"/>
  <registerval addr="20" value="7"/>
  <registerval addr="21" value="32"/>
  <registerval addr="22" value="50"/>
  <registerval addr="23" value="20"/>
  <registerval addr="24" value="8"/>
  <registerval addr="25" value="111"/>
  <registerval addr="26" value="46"/>
  <registerval addr="27" value="224"/>
  <registerval addr="28" value="143"/>
  <registerval addr="29" value="2"/>
  <registerval addr="2A" value="0"/>
  <registerval addr="2B" value="0"/>
  <registerval addr="2C" value="0"/>
  <registerval addr="2D" value="8"/>
  <registerval addr="2E" value="32"/>
  <registerval addr="3C" value="3"/>
</devicevalues>
