using the uart example ofADSP-21369 EZ-KIT Lite problem
Question asked by jett on Mar 17, 2011
Latest reply on Apr 19, 2011 by DeepV
HI all
i using the  UART echo back (C) example
now my put a value from pc ,then my 369 system is receive the data .and i find that the data i receive that is not equal to me sent.
when i change the baud rate the value which i received is not change yet.
void initUART()
    /* Sets the Baud rate for UART0 */
    *pUART0LCR = UARTDLAB;  //enables access to Divisor register to set baud rate
    *pUART0DLL = 0x1c;      //0x21c = 540 for divisor value and gives a baud rate of19200 for core clock 331.776MHz
    *pUART0DLH = 0x02;
    /* Configures UART0 LCR */
    *pUART0LCR = UARTWLS8;
                   // word length 8
                //   |UARTPEN|                 // parity enable ODD parity
               // UARTSTB ;                 // Two stop bits
    *pUART0RXCTL = UARTEN;       //enables UART0 in receive mod
  // *pUART0TXCTL = UARTEN;       //enables UART0 in core driven mode
      *pUART0IER   = UARTRBFIE;    // enables UART0 receive interrupt
    SRU(LOW,DPI_PB08_I) ;
  //  xmitUARTmessage(welcomemessage,sizeof(welcomemessage));
void UARTisr()
  int value,i, te
temp=*pUART0IIR;
   if((temp&4)==4)
     value = *pUART0RBR;
    // i  =   *pUART0LBR;                                      // UART Receive Buffer Register (RBR)
   if ((temp&2)==2)
         ;  // transmit interrupt code ->should enter here now
/* echoes back the value on to the hyperterminal screen*/
main()
    *pPICR2 &= ~(0x3E0); //Sets the UART0 receive interrupt to P13
    *pPICR2 |= (0x13<<5);
    initPLL_SDRAM();
    initTimer0 ();
    *pUART0LCR=0;
    interrupt(SIG_P13,UARTisr);
    initDPI();
    initUART();
   while(1)
hope some advice.
thanks
jett
