Slow usb bulk transfert using BF525
Question asked by Julien on Mar 4, 2011
Latest reply on Mar 15, 2011 by Julien
Hi Analog,
I have a little problem of speed while using USB device bulk tx transfert with BF525 : it seems that the blackfin controler is able to send only 2 or sometimes three packets (512 bytes) per micro-frame (125 µs), limiting the bandwidth to about 8000 kbytes / seconds.
For my application, I need to reach at least 15 Mbytes/seconds (video transfert).
You can find attached to this post a capture of my usb protocol analyser demonstrating that the Blackfin "nacks" too many transactions each micro-frame, as if the USB DMA was not able to fill  data as fast as needed.
I use DMA mode 1 for large packets, and DMA mode 0 for small packets (less than 512 bytes), and observe the same slowness in either case.
My configuration is as folllow (DMA mode 1) :
USB_TXCSR = bit 15 (AUTOSET_T), bit 12 (DMA_REQ_ENABLE), bit 10 (DMA mode 1)
USB_TXCOUNT = large packet size in bytes.
USB_DMAx_CONTROL(ep) = (ep << 4) | DMA_ENA | INT_ENA | bit 1 (direction = TX) | bit 2 (DMA mode 1)
pUSB_DMAx_COUNT = USB_TXCOUNT
So my questions are the followings:
- Have you ever seen this kind of problem before ?
- Have you any suggestions that could help me to improve the overall data rate ?
- Do you think it could be related to a SDRAM bottleneck ? In which case, what do you think I could do ? (the system clock is already running at 115,2 MHz, which seems very sufficient to me, and I already tried to disable other processing in the application while transmitting over usb -- without results) ?
I would be very gratefull for any suggestions,
Thanks by advance,
Julien
