Dual AD9361 Vivado Build : Critical Warning
Question asked by DEV$ on May 14, 2015
Latest reply on May 17, 2015 by DEV$
Hi Guyz,
Got the same problem as:
Dual AD9361 Vivado Build Error
Have changed the reference design and some of the file names with respect to my design changes.
In the above said link,  axi_ad9361_0 has been used as variable.
Referring that, just initialized a variable named i_dragonlite_intf in the xdc and tried runing the project.
Got DRC errors as said in the above post, [referring to the link] so tried like this:
set_property -dict [list CONFIG.PCORE_0_IODELAY_GROUP {dev_0_if_delay_group}] $i_dragonlite_intf
set_property -dict [list CONFIG.PCORE_1_IODELAY_GROUP {dev_1_if_delay_group}] $i_dragonlite_intf
Started getting Critical warning as :
CRITICAL WARNING: [Designutils 20-964] Command failed: can't read "i_dragonlite_intf": no such variable.
[D:/2_Digital_LB_pn/Dragon_Demo_an/dragon/dragon.srcs/constrs_1/imports/new/echocan_phy_lvds.xdc:386]
Just wanted to know, if there is anything else that I should take care from design point of view.
Can anybody please explain its usage / what value should be set to the variable and where & most importantly WHY ?
Thanks in advance,
Ananya
