AD9364 multibyte read/write implementation
Question asked by ravi@k2-inc.com on May 12, 2015
Latest reply on May 20, 2015 by ravi@k2-inc.com
Hello Forum,
I am implementing spi_write_then_read API for my MCU platform integrated with AD9364 over SPI using no-OS driver specified on http://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/baremetal#downloads
I see that the AD9364 no-OS driver uses following SPI multi-byte read/write command format
Bit15 : 1 = Write or 0 = read
Bit14:12 : 0 = 1 to 7 = 8 byte Multi-byte read/write command
Bit9:0 : 10 bit SPI register address
If write command, then the buffer follows with write values.
With this above format used in ADI provided no-OS driver, MCU is not able to do multi-byte SPI read/write operation on AD9364.
In order to make multi-byte SPI read/write operation on AD9364 on my MCU platform, I have to use following command format
Bit6:4 : 0 = 1 to 7 = 8 byte Multi-byte read/write command
Bit1: 0 : Bit 9:8 of 10 bit SPI register address
Next buffer:
Bit15:8 : Bit 7:0 of 10 bit SPI register address
My question is what settings are required in ADI AFE or SPI bus to make it work with ADI AFE provided multi-byte read/write format.
Ravi
