Building Linux for ZED board + FMCOMMS1
Question asked by jeffkt2 on May 12, 2015
Latest reply on May 18, 2015 by larsc
I'm having a few issues trying to run linux by following the instructions here:
Linux with HDMI video output on the ZED and ZC702, ZC706 boards [Analog Devices Wiki]
Everything is just fine until I get to building the device tree. The zynq-zed-adv7511-xcomm.dts does not exist in my arch/armboot/dts folder. There does exist a zynq-zed-adv7511-fmcomms1.dts, so I used that to build the device tree:
make zynq-zed-adv7511-fmcomms1.dtb
The device tree blob was generated successfully, and I copied all files to the SD card. When I try to book the board, I get the following error messages over the uart:
U-Boot 2012.10-00430-g2678622 (Dec 11 2012 - 16:47:06)
DRAM:  512 MiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
SF: Detected S25FL256S with page size 64 KiB, total 32 MiB
SF: Warning - Only lower 16MB is accessible in 3 byte addressing mode
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading uImage
3267632 bytes read
reading devicetree.dtb
15666 bytes read
reading uramdisk.image.gz
** Unable to read "uramdisk.image.gz" from mmc 0:1 **
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.19.0-g5b0956e
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3267568 Bytes = 3.1 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
Wrong Ramdisk Image Format
Ramdisk image is corrupt or invalid
Any help would be greatly appreciated!
Thanks
