gmake-378 no rule to make target problem
Question asked by amardeepd on Feb 1, 2011
Latest reply on Feb 1, 2011 by amardeepd
Hi all;
I am having a problem running a build of a project. It had been building fine and I was working through the errors re-building every one or two to ensure that I had fixed the issues. I had just commented out a break (I had commented out the case switch for a previous fix and forgot to comment out the break... doh!) and then I started getting the following error:
----------------Configuration: coreA - Debug----------------
C:\Program Files\Analog Devices\VisualDSP 5.0\gmake-378: *** No rule to make target `####################', needed by `Debug/coreA.doj'.  Stop.
No valid command(s) to build.
Build was unsuccessful.
I undid the last couple of fixes I had done even though I knew it had built fine in-between but I am still getting the error. I have tried to touch the installation and to check if there was a second gmake in the directory without an extention (which was someone elses problem) but to no avail. The error is coming up with all of my projects now but its not always for the coreA.doj (different projects have it stating a different needed by).
Any ideas?
