Power spectrum with meaningful levels
Question asked by sauwen on Jan 26, 2011
Latest reply on Mar 1, 2011 by gpan
I am trying to produce a power spectrum with meaningful levels on the dsp.  This is similar to MATLAB's reference: http://www.mathworks.com/support/tech-notes/1700/1702.html
My problem is that I want to utilize the fract16 datatype or use a 16-bit fixed point representation and avoid using floating point for efficiency.  After I do
rfft_fr16(input, output, twiddle_table, 1, FFT_SIZE, &block_exponent, 1); //get fft
for(i=0;i<FFT_SIZE/2;i++){
  power_fp[i] = output[i].re*output[i].re + output[i].im*output[i].im;  //this may overflow even when no scaling is done..
                           //beware, results of overflow becomes negative number
What happens is that even before I scale anything, my output has overflowed.
I believe I may be missing a crucial step though.. converting from fr16 fractional values from -1 to 1 to fixed point values -32768 to 32767.  I can't just insert the values given to me into the -1 to 1 of my fixed point representation or else I'll be losing a lot of information.  The easy (cop out) way would be to do this:
outputf[i].re=fr16_to_float(output[i].re)*ldexpf(1.0F,block_exponent);
outputf[i].im=fr16_to_float(output[i].im)*ldexpf(1.0F,block_exponent);
and the divide by the 2^(fractional bits) to obtain my fixed point value.  That would involve changing back to float.  Would this be my only option?  Am I on track or way off?  Any suggestions are most welcome.
Thank you
