ADSP 21364 processing too long
Question asked by makary87 on Jan 25, 2011
Latest reply on Feb 2, 2011 by DivyaS
I'm a beginer in programing on DSP boards. And I have a problem. I am using example from visualdsp++ BlockBasedTalkThru(C) example. I applied a some porcessing in finction processBlock. And it is not working. By using debuger i get that proccesing is to long. How can I solve this problem?
Below I put my code:
#include "tt.h"
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <complex.h>
#include <filter.h>
// Place the audio processing algorith here. The input and output are given
// as unsigned integer pointers.
void processBlock(unsigned int *block_ptr,complex_float *x,complex_float *X,complex_float *x1,complex_float *X1,complex_float *c,complex_float *C,complex_float alfa,complex_float delta,complex_float delta_pier,complex_float new_C, int N)
    int i;
    float temp_out,sample;
    int n;
    //Clear the Block Ready Semaphore
    blockReady = 0;
    //Set the Processing Active Semaphore before starting processing
    isProcessing = 1;
     for(i=0;i<NUM_SAMPLES;i=i+2){
         n = i/2;
        x[n].re = (float)(int)((*(block_ptr+i)) << 8);
         // x[n].re = 0;
        x1[n].re = (float)(int)((*(block_ptr+i+1)) << 8);
   cfft512(x,X);
   cfft512(x1,X1);
     for(i=0;i<NUM_SAMPLES/2;i++)
        if((sqrt((X[i].re*X[i].re)+(X[i].im*X[i].im)) !=0)  &&  (sqrt((X1[i].re*X1[i].re)+(X1[i].im*X1[i].im)) !=0)) {
         C[i].re = (X[i].re/sqrt((X[i].re*X[i].re)+(X[i].im*X[i].im)) + X1[i].re/sqrt((X1[i].re*X1[i].re)+(X1[i].im*X1[i].im)));
         C[i].im = (X[i].im/sqrt((X[i].re*X[i].re)+(X[i].im*X[i].im)) + X1[i].im/sqrt((X1[i].re*X1[i].re)+(X1[i].im*X1[i].im)));
     else
         C[i].re = 0;
         C[i].im = 0;
SOMETHING MORE
        new_C = cmlt(alfa,C[i]);
      C[i] = new_C;
ifft512(C,c);
       n=i/2;
    *(block_ptr+i) =  (unsigned)(((int)c[n].re) >> 8);
    *(block_ptr+i+1) =  (unsigned)(((int)c[n].re) >> 8);
    //Clear the Processing Active Semaphore after processing is complete
    isProcessing = 0;
