files disappear and reappear with fss fat32 on SDHC
Question asked by jeanmichel on Jan 19, 2011
Latest reply on Jan 26, 2011 by jeanmichel
I'm using Visual DSP++ Update 8 with an ADSP-BF518F EZ-BOARD.
I want to access an SD HC card (4GB) (FAT32) to read and write files.
I am using directly functions from adi_fss (like adi_fss_FileOpen).
In the main code I write a file then I read it.
I never have any problem to write the file. But to read it, I need first to write into it. And if I restart the board with a new program without the file writing part , it does not find the file.
Even better, I put some files on the card with my computer. Then I start the program on the board (and then I write the file bb on the card). If I put the board again in the computer (windows xp) it just find the file bb (the other files disappeared). Then I copy one file with the computer on the card and I eject the card from the computer. I plug again the card in the computer and then all files reappeared .... I tried to reformat it does not help.
Any clue ?
Thanks a lot.
Jena Michel LECONTE
Main Code
int main( void )
int n;
// init services
u32 Result=InitServices();
Init_LEDs();
ADI_FSS_WCHAR name[50];
char ledvalue=0;
if ( !Result ) {
        /* Initialize the file system */
        Result = InitFileSystem();
        do {
            u32 Result = ADI_FSS_RESULT_SUCCESS;
            ADI_FSS_FILE_HANDLE fh;
          /* write file bb */
          Result=adi_fss_FileOpen("bb",strlen("bb"),ADI_FSS_MODE_READ_WRITE|ADI_FSS_MODE_CREATE|ADI_FSS_MODE_APPEND,&fh);
          /* close it */
          adi_fss_FileClose(fh);
           /* read file bb */
           Result=adi_fss_FileOpen("bb",strlen("bb"),ADI_FSS_MODE_READ,&fh);
   if (Result==ADI_FSS_RESULT_SUCCESS) {
int n;
printf("File opened ! \n");
n=0;
while (n<200000000)
u32 sizeread,i;
//     i=fread(bufferread,sizeof(char),(1024) ,fp);
Result=adi_fss_FileRead(fh,(u8*)bufferread,16384,&sizeread);
if (Result == ADI_FSS_RESULT_SUCCESS)
n+=sizeread;
else
if (Result==ADI_FSS_RESULT_EOF)
printf("end of file !");
else
printf("another error! ");
printf("Read\n");
/* close file */
Result=adi_fss_FileClose(fh);
if (Result!=ADI_FSS_RESULT_SUCCESS) printf("Cannot close file !\n");
else {
printf("Unable to read file \n");
        }while(0);
while(1){;}
/* Begin adding your custom code here */
return 0;
Fssinit
ADI_FSS_CMD_VALUE_PAIR adi_fss_Config[] = {
/* Set up File Cache Size */         { ADI_FSS_CMD_SET_NUMBER_CACHE_BLOCKS,  (void*)2 },
/* Set up Heap Index of the FSS General Heap */        { ADI_FSS_CMD_SET_GENERAL_HEAP_ID,      (void*)GeneralHeapID },
/* Register the SDH interface driver */         { ADI_FSS_CMD_ADD_DRIVER,               (void*)&ADI_SDH_Def },
/* Register the FAT File System driver */         { ADI_FSS_CMD_ADD_DRIVER,               (void*)&ADI_FAT_Def },
/* Assign the DMA Manager Handle */         { ADI_FSS_CMD_SET_DMA_MGR_HANDLE,       (void*)adi_dma_ManagerHandle },
/* Assign the Device Manager Handle */         { ADI_FSS_CMD_SET_DEV_MGR_HANDLE,       (void*)adi_dev_ManagerHandle },
/* Assign the DCB Queue Handle */         { ADI_FSS_CMD_SET_DCB_MGR_HANDLE,       (void*)adi_dcb_QueueHandle },
/* Command Table Terminator */         { ADI_FSS_CMD_END,
(void*)NULL }     };
init services
#define ADI_SSL_INT_NUM_SECONDARY_HANDLERS  (10) // number of secondary interrupt handlers
#define ADI_SSL_DCB_NUM_SERVERS             (1) // number of DCB servers
#define ADI_SSL_DMA_NUM_CHANNELS            (4) // number of DMA channels
#define ADI_SSL_FLAG_NUM_CALLBACKS          (0) // number of flag callbacks
#define ADI_SSL_SEM_NUM_SEMAPHORES          (40) // number of semaphores
#define ADI_SSL_DEV_NUM_DEVICES             (4) // number of device drivers
