Setting up a fractional-divider loop with AD9956
Question asked by johnlzy on Jan 4, 2011
Latest reply on Jan 20, 2011 by johnlzy
Hi there,
I'm hoping someone will help me with a problem regarding the set up of the fractional-divider loop on the AD9956 evaluation board. I've purchased the AD9956-VCO/PCB-Z boards and I've been trying to set this up to no avail.
I've taken a look at the data sheet and noticed that they've recommended this setup (pg 16):
With the eval board, I've connected it as such:
DUT FILTER OUT (J6) to DUT OSC IN (J3)
VCO OUT (J16) to DUT RF_IN (J1)
VCO OUT (J16) also to split to a Spectrum Analzyer
These are the settings that I've set:
Control
Clock
Ref Clock: 2400 MHz
RF Divider RefClk Mux: Unchecked
Divider Ratio: 8
System Clock: 300 MHz
RF Divider Reset Enable: Unchecked
RF Divider Reset Mode: 0
Accumulator Control, Power Down, SyncMulti DUT's
(All unchecked)
Output Waveform
Cosine
Linear Sweep
Enable: Checked
No Dwell: Unchecked
Load SRR @ I/O Update: Unchecked
Profile
Profile 0
Output Freq: 24.00000
Offset: 0.000
Profile 1
Output Freq: 25.00000
Offset: 0.000
Clock Driver Control, Phase Frequency Detector & Charge Pump
Charge Pump Full Powerdown: Unchecked
Charge Pump Quick Powerdown: Unchecked
Enable Crystal Oscillator: Checked
RSet Value: 3090
Charge Pump Current: 4.013 mA
Charge Pump Polarity: GND Reference VCO
Divider N/M : Bypass
PLL Lock Enable: PLL Lock detect
PLL Lock Mode: Lock Detect
What I've observed is a static frequency at 2.315 GHz while I should be expecting a chirp frequency.
Thanks and Regards,
John
