Problem in using cfft function
Question asked by Senthil on Dec 14, 2010
Latest reply on Dec 15, 2010 by Senthil
Hi all,
      I am trying to implement 32 Point FFT using VDSP in-built function as reference. First I used cfftf_simd.asm residing at “C:\ Program Files\Analog Devices\VisualDSP 5.0\214xx\lib\src\libdsp_src\” to implement 128 point FFT.
void cfftf            (float data_real[], float data_imag[],
             float temp_real[]. float temp_imag[],
             const float twid_real[],
const float twid_imag[],
             int n);
But from the comments provided in the file it is found that 32 point is not possible with that routine. So we used routine in cfft_simd.asm attached herewith,
complex_float *cfft32    (complex_float dm input[],
                                                  complex_float dm output[]);
Passing arguments for that routine is input buffer and output buffer address. In the document it is said to keep both buffer of size ‘N’ where N is the FFT points.
In that case whether input buffer should be interleaved with real and imaginary values. Then what we will get in the output buffer.
Expecting a quick response. Thanks in advance.
Senthil
