Critical warnings on implemetation of HDL-HDL_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.xpr
Question asked by yanjiesh on May 11, 2015
Latest reply on May 12, 2015 by yanjiesh
Dear concerned,
I am studying the AD9361 module in this project. When I tried to implement the project, it responded with the following critical warnings, I am confused because the relevant codes had been downloaded from analogdevicesinc/hdl at hdl_2014_r1 · GitHub, directly.
Could someone tell me how to deal with the warnings? What are the reasons?
_______________________________________________________________________________________________________________
  • Implementation
  • Design Initialization
  • [Vivado 12-1387] No valid object(s) found for set_clock_groups constraint with option '-group [get_clocks -of_objects [get_pins i_system_wrapper/system_i/axi_spdif_tx_core/U0/S_AXIS_ACLK]]'. ["f:/2014/AD9361/hdl-hdl_2014_r1/hdl-hdl_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/ip/system_axi_spdif_tx_core_0/axi_spdif_tx_constr.xdc":3]
  • [Vivado 12-1387] No valid object(s) found for set_clock_groups constraint with option '-group [get_clocks -of_objects [get_pins i_system_wrapper/system_i/axi_ad9361_dac_dma/inst/fifo_wr_clk]]'. ["f:/2014/AD9361/hdl-hdl_2014_r1/hdl-hdl_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/ip/system_axi_ad9361_dac_dma_0/axi_dmac_constr.xdc":2]
  • [Vivado 12-1387] No valid object(s) found for set_clock_groups constraint with option '-group [get_clocks -of_objects [get_pins i_system_wrapper/system_i/axi_ad9361_dac_dma/inst/m_dest_axi_aclk]]'. ["f:/2014/AD9361/hdl-hdl_2014_r1/hdl-hdl_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/ip/system_axi_ad9361_dac_dma_0/axi_dmac_constr.xdc":3]
  • [Vivado 12-1387] No valid object(s) found for set_clock_groups constraint with option '-group [get_clocks -of_objects [get_pins i_system_wrapper/system_i/axi_ad9361_dac_dma/inst/fifo_rd_clk]]'. ["f:/2014/AD9361/hdl-hdl_2014_r1/hdl-hdl_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/ip/system_axi_ad9361_dac_dma_0/axi_dmac_constr.xdc":4]
  • [Vivado 12-1387] No valid object(s) found for set_clock_groups constraint with option '-group [get_clocks -of_objects [get_pins i_system_wrapper/system_i/axi_ad9361_adc_dma/inst/fifo_wr_clk]]'. ["f:/2014/AD9361/hdl-hdl_2014_r1/hdl-hdl_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/ip/system_axi_ad9361_adc_dma_1/axi_dmac_constr.xdc":2]
  • [Vivado 12-1387] No valid object(s) found for set_clock_groups constraint with option '-group [get_clocks -of_objects [get_pins i_system_wrapper/system_i/axi_ad9361_adc_dma/inst/fifo_rd_clk]]'. ["f:/2014/AD9361/hdl-hdl_2014_r1/hdl-hdl_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/ip/system_axi_ad9361_adc_dma_1/axi_dmac_constr.xdc":4]
  • [Vivado 12-1387] No valid object(s) found for set_clock_groups constraint with option '-group [get_clocks -of_objects [get_pins i_system_wrapper/system_i/axi_ad9361_adc_dma/inst/m_src_axi_aclk]]'. ["f:/2014/AD9361/hdl-hdl_2014_r1/hdl-hdl_2014_r1/projects/fmcomms2/zed/fmcomms2_zed.srcs/sources_1/bd/system/ip/system_axi_ad9361_adc_dma_1/axi_dmac_constr.xdc":5]
________________________________________________________________________________________________________________
Jie
2015-5-12
