EKIT01-HMC830LP6GE
Question asked by kotoo@fujiele.co.jp on May 11, 2015
Latest reply on May 12, 2015 by dyoung1
EKIT01-HMC830LP6GE is used.
I would like to output 160MHz by Integer Mode.
==Environment==
Hardware:EKIT01-HMC830LP6GE
Software:PLL Eval Software V3_2_4_0 and V3_2_5_0(The problem has occurred by both.)
OS:Win7 32bit
==The first confirmation==
The current value of the power supply is confirmed (current value of the stabilizing supply).
=>[I do not remember an accurate value but 0.2-0.3A]
It confirms it by 00h register reading with this software.
=>[Device ID A7975]
Writing and read backing to 02h register
=>[The read buck value is a written value.]
If Out Frequency Desired is adjusted to 160MHz and Update , it becomes Out Frequency=158.33MHz.
I append the above-mentioned problem Fig.
The VCO frequency is 1.5GHz-3.0GHz.
So,I think that it can achieve 160MHz by the following setting.
Ex1)  XTAL=50MHz,VCO=1.6GHz,R=1,N=32,O=10
Ex2)  XTAL=50MHz,VCO=2.4GHz,R=1,N=48,O=15
Why is not this set with 160MHz?
Thank you.
