Ad5757 from eval board doesn't answer
Question asked by ArturB on May 7, 2015
Latest reply on May 15, 2015 by ArturB
I have evaluation board with AD5757 for two days. I would like to check that communication is working properly, so I want to read data from register without success. The second option is to turn on alarm led on the board by watchdog because of no communication.
I have no clue why it does not answer me. I checked communication twice with logic analyzer and once with oscilloscope.
Eval board is connected to Raspberry pi. You can see script, which I use to test communication.
As a summary I can say that I use 0x9C, 0x2F, 0x00 to enable watchdog for 200ms and then wait 2 seconds without communication.
Then I send 0x98, 0x00, 0x00 to read status register and afterwards I send no operation 0x1C, 0xE0, 0x00.
Could someone confirm that this sequence is the correct one please?
I can provide dump from logic analyzer if required.
If more details is necessary feel free to ask.
#!/usr/bin/python
import spidev
import RPi.GPIO as GPIO
from time import sleep
import sys
spi0=spidev.SpiDev()
spi0.open(0,0)
spi0.max_speed_hz=500000
spi0.mode = 1
GPIO.setmode(GPIO.BOARD)
GPIO.setup(7, GPIO.OUT)
GPIO.setup(11, GPIO.OUT)
GPIO.output(7, GPIO.HIGH)
GPIO.output(11, GPIO.HIGH)
sleep(0.1)
print spi0.xfer2([0x9C, 0x2F, 0x00])
sleep(2)
print spi0.xfer2([0x98, 0x00, 0x00])
print spi0.xfer2([0x1C, 0xE0, 0x00])
GPIO.output(7, GPIO.LOW)
sleep(0.01)
spi0.close()
GPIO.cleanup()
exit()
