Question on 21469 TalkThru examples
Question asked by MikeSmithCanada on Dec 6, 2010
Latest reply on Dec 10, 2010 by CraigG
Trying the 21469 Talkthru examples in VDSP5.8
I got the Block Based one going easily enough by following audio cable set-up instructions
In on left set of input RCA connectors channels
Out on second row of output RCA connectors
In on right set of input RCA connectors channels
Out on third row of output RCA connectors
But could not get the point talkthru going -- which by Murphy's Law is the one I needed for a class
Spend some time checking the switches
QUESTION 1 -- The 8 pin switches have clearly marked on and off settings
For future reference, is there a mark on the 2 pin switches showing which is ON and OFF setting?
QUESTION 2
Finally got the point talkthru going, by changing the RCA connector positions
meaning
Out on THIRD row of output RCA connectors
Out on SECOND row of output RCA connectors
This switch of positions is actually mentioned in the readme.txts
These txt files read a little confusing as the point readme.txt seems to have a reference to the block code example
which led me to intially to believe the audio cable settings would be the same.
Is there a logical reason for this switch of output positions, meaning a third demo where both point DMA and block DMA are going at the same time?
I could use that working example as a class demo if there was.
Thanks
