Read registers of AD7747, C# code
Question asked by ibs on May 6, 2015
Latest reply on May 13, 2015 by Stephen_Nugent
hi to all,
I am working with evaluation board of AD7747 and after importing ADI_CYUSB_USB.dll to C# environment I found the board and writing to registers commands turned no error (0). I configured it as following:
1. register 0x7 set to 0xa0
2. register 0xb set to 0;
3. register 0x9 set to 0xe
4. register 0xa set to 0xa1
the configuration is carried out by Vendor_Request_Imp(uint Handle, byte Request, ushort Value, ushort Index, byte Direction, ushort DataLength, ref byte[] Buffer)
I would like to read registers to verify write command is correct and after that read the CAP data registers (1-3)
The problem is that I get error 3011.
I use the method as following: int read_flag=Vendor_Request_Imp(Handle, 0xdd, 0, 0x1, 1, 3, ref data)
Is there a write command that is missing? or do I use the method uncorrectly in read command?
IBS
