Question regarding Vivado
Question asked by BruceZhao on Apr 21, 2015
Latest reply on Apr 30, 2015 by AdrianC
Branched from an earlier discussion
Hi Adrian,
The message of vivado.log shows below:
# Vivado v2014.2 (64-bit)
# SW Build 932637 on Wed Jun 11 13:33:10 MDT 2014
# IP Build 924643 on Fri May 30 09:20:16 MDT 2014
# Start of session at: Tue Apr 21 14:39:24 2015
# Process ID: 4016
# Log file: C:/Users/Administrator/AppData/Roaming/Xilinx/Vivado/vivado.log
# Journal file: C:/Users/Administrator/AppData/Roaming/Xilinx/Vivado\vivado.jou
start_gui
open_project C:/Users/Administrator/managed_ip_project/managed_ip_project.xpr
Scanning sources...
Finished scanning sources
WARNING: [Project 1-231] Project 'managed_ip_project.xpr' was created with a future version and may or may not perform reliably with this version of Vivado. It has been opened in read-only mode for the protection of unrecognized data. Use 'File | Save Project As...' if you wish to alter a copy of the project.
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'D:/Xilinx2014.2/Vivado/2014.2/data/ip'.
open_project: Time (s): cpu = 00:00:12 ; elapsed = 00:00:06 . Memory (MB): peak = 823.309 ; gain = 0.000
INFO: [IP_Flow 19-1839] IP Catalog is up to date.
close_project
exit
INFO: [Common 17-206] Exiting Vivado at Tue Apr 21 15:03:41 2015...
what to do next??
Thanks.
