ADV7611 iMX6 settings
Question asked by FreddyS on Apr 28, 2015
Latest reply on Jan 27, 2017 by JeyasudhaMuthuPerumal
I have a problem with the ADV7611 operation on the iMX6Q based device.
I am not sure that ADV7611 output is compatible at all.
Please refer to the attached documents. As you can see CSI input of  freescale iMX6  can accept only these modes below:
RGB565 8 bits 2 or 3 cycles
RGB666 8 bits 3 cycles
RGB888 8 bits 3 cycles
YCbCr  8 bits 2 cycles
RGB565 16 bits 2 cycles
YCbCr 16 or 20 bits 1 cycle
So the selected output of ADV7611 is:
"8-Bit SDR ITU-R BT.656 Mode 0" (from "ADV7611 (Rev. D).pdf")
and CSI input
"YCbCr  8 bits 2 cycles"
Does YCbCr requires 3 cycles?
Am I missing something with the cycles issue?
The same interface works with ADV7181C nicely. So I am not sure that 2/3 cycles is a problem.
In addition, can you check my initialization sequence (attached too) is the last updated one? Every each bit...
I took it from "ADV7611-Version 3.0c.txt" script for the evaluation board and added my own settings based on reading documentation.
Note:  my driver does not use interrupts. Is handling of interrupts necessary?
Thanks a lot for your advise and directions.
Freddy
