Custom board doesn't find AD9361
Question asked by hgomiz on Apr 28, 2015
Latest reply on May 6, 2015 by hgomiz
I'm trying to make work the AD-FMCOMMS3-EBZ in a custom board with a xc7z015clg485-1 ZYNQ FPGA.
So far i have adapted the project in vivado, taking away the following:HDMI, USB0, SPI1, iic, i2s, spdif, GPIO.
So the gateware looks like this now:
Screenshot from 2015-04-28 16:13:46.png
I have generated the BOOT.bin with the new gateware, and I'm using a uImage created for my custom board. I have also created the devictree.dtb with SDK ,which can be seen at the botom . So far the Linux is working on my board but the AD9361 doesn't seem to be found . it is not in /sys/bus/iio/devices/iio:device1, only de XADC is there (device0).
What am I missing? should I put the AD9361 driver somwhere? or is the devictree wrong?
I would appreciate any help.
Devicetree:
/dts-v1/;
  #address-cells = <0x1>;
  #size-cells = <0x1>;
  compatible = "xlnx,zynq-7000";
  chosen {
  aliases {
  ethernet0 = "/amba/ethernet@e000b000";
  serial0 = "/amba/serial@e0000000";
  memory {
  device_type = "memory";
  reg = <0x0 0x20000000>;
  cpus {
  #size-cells = <0x0>;
  cpu@0 {
  compatible = "arm,cortex-a9";
  device_type = "cpu";
  reg = <0x0>;
  clocks = <0x1 0x3>;
  clock-latency = <0x3e8>;
  cpu0-supply = <0x2>;
  operating-points = <0xa2c2a 0xf4240 0x51615 0xf4240>;
  cpu@1 {
  reg = <0x1>;
  clocks = <0x1 0x3>;
  pmu {
  compatible = "arm,cortex-a9-pmu";
  interrupts = <0x0 0x5 0x4 0x0 0x6 0x4>;
  interrupt-parent = <0x3>;
  reg = <0xf8891000 0x1000 0xf8893000 0x1000>;
  fixedregulator@0 {
  compatible = "regulator-fixed";
  regulator-name = "VCCPINT";
  regulator-min-microvolt = <0xf4240>;
  regulator-max-microvolt = <0xf4240>;
  regulator-boot-on;
  regulator-always-on;
  linux,phandle = <0x2>;
  phandle = <0x2>;
  amba {
  compatible = "simple-bus";
  ranges;
  adc@f8007100 {
  compatible = "xlnx,zynq-xadc-1.00.a";
  reg = <0xf8007100 0x20>;
  interrupts = <0x0 0x7 0x4>;
  clocks = <0x1 0xc>;
  can@e0008000 {
  compatible = "xlnx,zynq-can-1.0";
  status = "disabled";
  clocks = <0x1 0x13 0x1 0x24>;
  clock-names = "can_clk", "pclk";
  reg = <0xe0008000 0x1000>;
  interrupts = <0x0 0x1c 0x4>;
  tx-fifo-depth = <0x40>;
  rx-fifo-depth = <0x40>;
  can@e0009000 {
  clocks = <0x1 0x14 0x1 0x25>;
  reg = <0xe0009000 0x1000>;
  interrupts = <0x0 0x33 0x4>;
  gpio@e000a000 {
  compatible = "xlnx,zynq-gpio-1.0";
  #gpio-cells = <0x2>;
  clocks = <0x1 0x2a>;
  gpio-controller;
  interrupts = <0x0 0x14 0x4>;
  reg = <0xe000a000 0x1000>;
  i2c@e0004000 {
  compatible = "cdns,i2c-r1p10";
  clocks = <0x1 0x26>;
  interrupts = <0x0 0x19 0x4>;
  reg = <0xe0004000 0x1000>;
  i2c@e0005000 {
  clocks = <0x1 0x27>;
  interrupts = <0x0 0x30 0x4>;
  reg = <0xe0005000 0x1000>;
  interrupt-controller@f8f01000 {
  compatible = "arm,cortex-a9-gic";
  #interrupt-cells = <0x3>;
  interrupt-controller;
  reg = <0xf8f01000 0x1000 0xf8f00100 0x100>;
  num_cpus = <0x2>;
  num_interrupts = <0x60>;
  linux,phandle = <0x3>;
  phandle = <0x3>;
  cache-controller@f8f02000 {
  compatible = "arm,pl310-cache";
  reg = <0xf8f02000 0x1000>;
  arm,data-latency = <0x3 0x2 0x2>;
  arm,tag-latency = <0x2 0x2 0x2>;
  cache-unified;
  cache-level = <0x2>;
  memory-controller@f8006000 {
  compatible = "xlnx,zynq-ddrc-1.0";
  reg = <0xf8006000 0x1000>;
  xlnx,has-ecc = <0x0>;
  ocmc@f800c000 {
  compatible = "xlnx,zynq-ocmc-1.0";
  interrupts = <0x0 0x3 0x4>;
  reg = <0xf800c000 0x1000>;
  serial@e0000000 {
  compatible = "xlnx,xuartps", "cdns,uart-r1p8";
  status = "okay";
  clocks = <0x1 0x17 0x1 0x28>;
  clock-names = "uart_clk", "pclk";
  reg = <0xe0000000 0x1000>;
  interrupts = <0x0 0x1b 0x4>;
  current-speed = <0x1c200>;
  device_type = "serial";
  port-number = <0x1>;
  serial@e0001000 {
  clocks = <0x1 0x18 0x1 0x29>;
  reg = <0xe0001000 0x1000>;
  interrupts = <0x0 0x32 0x4>;
  spi@e0006000 {
  compatible = "xlnx,zynq-spi-r1p6";
  reg = <0xe0006000 0x1000>;
  status = "okay";
  interrupts = <0x0 0x1a 0x4>;
  clocks = <0x1 0x19 0x1 0x22>;
  clock-names = "ref_clk", "pclk";
  is-decoded-cs = <0x0>;
  num-cs = <0x3>;
  spi@e0007000 {
  reg = <0xe0007000 0x1000>;
  interrupts = <0x0 0x31 0x4>;
  clocks = <0x1 0x1a 0x1 0x23>;
  spi@e000d000 {
  clocks = <0x1 0xa 0x1 0x2b>;
  compatible = "xlnx,zynq-qspi-1.0";
  status = "okay";
  interrupts = <0x0 0x13 0x4>;
  reg = <0xe000d000 0x1000>;
  is-dual = <0x0>;
  num-cs = <0x1>;
  memory-controller@e000e000 {
  clock-names = "memclk", "aclk";
  clocks = <0x1 0xb 0x1 0x2c>;
  compatible = "arm,pl353-smc-r2p1";
  interrupts = <0x0 0x12 0x4>;
  ranges;
  reg = <0xe000e000 0x1000>;
  flash@e1000000 {
  compatible = "arm,pl353-nand-r2p1";
  reg = <0xe1000000 0x1000000>;
  flash@e2000000 {
  compatible = "cfi-flash";
  reg = <0xe2000000 0x1000>;
  ethernet@e000b000 {
  compatible = "xlnx,ps7-ethernet-1.00.a";
  reg = <0xe000b000 0x1000>;
  status = "okay";
  interrupts = <0x0 0x16 0x4>;
  clocks = <0x1 0xd 0x1 0x1e>;
  clock-names = "ref_clk", "aper_clk";
  local-mac-address = [00 0a 35 00 00 00];
  xlnx,has-mdio = <0x1>;
  phy-mode = "rgmii-id";
  xlnx,ptp-enet-clock = <0x69f6bcb>;
  mdio {
  ethernet@e000c000 {
  reg = <0xe000c000 0x1000>;
  interrupts = <0x0 0x2d 0x4>;
  clocks = <0x1 0xe 0x1 0x1f>;
  sdhci@e0100000 {
  compatible = "arasan,sdhci-8.9a";
  status = "okay";
  clock-names = "clk_xin", "clk_ahb";
  clocks = <0x1 0x15 0x1 0x20>;
  interrupts = <0x0 0x18 0x4>;
  reg = <0xe0100000 0x1000>;
  clock-frequency = <0x2faf080>;
  sdhci@e0101000 {
  clocks = <0x1 0x16 0x1 0x21>;
  interrupts = <0x0 0x2f 0x4>;
  reg = <0xe0101000 0x1000>;
  slcr@f8000000 {
  compatible = "xlnx,zynq-slcr", "syscon";
  reg = <0xf8000000 0x1000>;
  ranges;
  clkc@100 {
  #clock-cells = <0x1>;
  compatible = "xlnx,ps7-clkc";
  ps-clk-frequency = <0x1fca055>;
  fclk-enable = <0x7>;
  clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x", "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x", "dci", "lqspi", "smc", "pcap", "gem0", "gem1", "fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1", "sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1", "dma", "usb0_aper", "usb1_aper", "gem0_aper", "gem1_aper", "sdio0_aper", "sdio1_aper", "spi0_aper", "spi1_aper", "can0_aper", "can1_aper", "i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper", "gpio_aper", "lqspi_aper", "smc_aper", "swdt", "dbg_trc", "dbg_apb";
  reg = <0x100 0x100>;
  linux,phandle = <0x1>;
  phandle = <0x1>;
  dmac@f8003000 {
  compatible = "arm,pl330", "arm,primecell";
  reg = <0xf8003000 0x1000>;
  interrupt-names = "abort", "dma0", "dma1", "dma2", "dma3", "dma4", "dma5", "dma6", "dma7";
  interrupts = <0x0 0xd 0x4 0x0 0xe 0x4 0x0 0xf 0x4 0x0 0x10 0x4 0x0 0x11 0x4 0x0 0x28 0x4 0x0 0x29 0x4 0x0 0x2a 0x4 0x0 0x2b 0x4>;
  #dma-cells = <0x1>;
  #dma-channels = <0x8>;
  #dma-requests = <0x4>;
  clocks = <0x1 0x1b>;
  clock-names = "apb_pclk";
  devcfg@f8007000 {
  clock-names = "ref_clk", "fclk0", "fclk1", "fclk2", "fclk3";
  clocks = <0x1 0xc 0x1 0xf 0x1 0x10 0x1 0x11 0x1 0x12>;
  compatible = "xlnx,zynq-devcfg-1.0";
  interrupts = <0x0 0x8 0x4>;
  reg = <0xf8007000 0x100>;
  timer@f8f00200 {
  compatible = "arm,cortex-a9-global-timer";
  reg = <0xf8f00200 0x20>;
  interrupts = <0x1 0xb 0x301>;
  clocks = <0x1 0x4>;
  timer@f8001000 {
  interrupts = <0x0 0xa 0x4 0x0 0xb 0x4 0x0 0xc 0x4>;
  compatible = "cdns,ttc";
  clocks = <0x1 0x6>;
  reg = <0xf8001000 0x1000>;
  timer@f8002000 {
  interrupts = <0x0 0x25 0x4 0x0 0x26 0x4 0x0 0x27 0x4>;
  clocks = <0x1 0x6>;
  reg = <0xf8002000 0x1000>;
  timer@f8f00600 {
  interrupts = <0x1 0xd 0x301>;
  compatible = "arm,cortex-a9-twd-timer";
  reg = <0xf8f00600 0x20>;
  clocks = <0x1 0x4>;
  watchdog@f8005000 {
  clocks = <0x1 0x2d>;
  compatible = "xlnx,zynq-wdt-r1p2";
  device_type = "watchdog";
  interrupts = <0x0 0x9 0x1>;
  reg = <0xf8005000 0x1000>;
  reset = <0x0>;
  timeout-sec = <0xa>;
  usb@e0002000 {
  clocks = <0x1 0x1c>;
  compatible = "xlnx,ps7-usb-1.00.a", "xlnx,zynq-usb-1.00.a";
  interrupts = <0x0 0x15 0x4>;
  reg = <0xe0002000 0x1000>;
  usb@e0003000 {
  clocks = <0x1 0x1d>;
  interrupts = <0x0 0x2c 0x4>;
  reg = <0xe0003000 0x1000>;
  amba_pl {
  ranges;
  axi_ad9361@79020000 {
  compatible = "xlnx,axi-ad9361-1.0";
  reg = <0x79020000 0x10000>;
  xlnx,s-axi-min-size = <0xffff>;
  axi_dmac@7c400000 {
  compatible = "xlnx,axi-dmac-1.0";
  reg = <0x7c400000 0x10000>;
  xlnx,2d-transfer = <0x0>;
  xlnx,axi-slice-dest = <0x0>;
  xlnx,axi-slice-src = <0x0>;
  xlnx,clks-async-dest-req = <0x1>;
  xlnx,clks-async-req-src = <0x1>;
  xlnx,clks-async-src-dest = <0x1>;
  xlnx,cyclic = <0x0>;
  xlnx,dma-axi-protocol-dest = <0x1>;
  xlnx,dma-axi-protocol-src = <0x0>;
  xlnx,dma-data-width-dest = <0x40>;
  xlnx,dma-data-width-src = <0x40>;
  xlnx,dma-length-width = <0x18>;
  xlnx,dma-type-dest = <0x0>;
  xlnx,dma-type-src = <0x2>;
  xlnx,fifo-size = <0x4>;
  xlnx,max-bytes-per-burst = <0x80>;
  xlnx,sync-transfer-start = <0x1>;
  axi_dmac@7c420000 {
  reg = <0x7c420000 0x10000>;
  xlnx,axi-slice-dest = <0x1>;
  xlnx,cyclic = <0x1>;
  xlnx,dma-axi-protocol-dest = <0x0>;
  xlnx,dma-axi-protocol-src = <0x1>;
  xlnx,dma-type-dest = <0x2>;
  xlnx,dma-type-src = <0x0>;
  xlnx,sync-transfer-start = <0x0>;
