util_wfifo_ip interfaces error
Question asked by dfox on Apr 27, 2015
Latest reply on May 4, 2015 by rejeesh
Branched from an earlier discussion
Did you ever get the below errors when sourcing the util_wfifo_ip.tcl?
IP PackagerIP Interfaces Wizard[IP_Flow 19-3254] Bus Interface 'fifo': The master AXIMM interface used as a write channel requires port maps to interface signals AWADDR, AWVALID, AWREADY, WDATA, WVALID, WREADY, BVALID and BREADY.  Found missing port map(s) for: AWADDR AWVALID AWREADY WVALID WREADY BVALID BREADY.
[IP_Flow 19-3253] Bus Interface 'fifo': The master AXIMM interface used as a read channel requires port maps to interface signals ARADDR, ARVALID, ARREADY, RDATA, RVALID and RREADY.  Found missing port map(s) for: ARADDR ARVALID ARREADY RVALID RREADY.
[IP_Flow 19-3257] Bus Interface 'm': The slave AXIMM interface used as a write channel requires port maps to interface signals AWADDR, AWVALID, AWREADY, WDATA, WVALID, WREADY, BVALID and BREADY.  Found missing port map(s) for: AWADDR AWVALID AWREADY WVALID WREADY BVALID BREADY.
[IP_Flow 19-3254] Bus Interface 's': The master AXIMM interface used as a write channel requires port maps to interface signals AWADDR, AWVALID, AWREADY, WDATA, WVALID, WREADY, BVALID and BREADY.  Found missing port map(s) for: AWADDR AWVALID AWREADY WVALID WREADY BVALID BREADY.
