Built trouble of AD-FMCMOTOCON1-EBZ
Question asked by Kaos on Apr 28, 2015
Latest reply on May 12, 2015 by Kaos
Dear Sir/Madam,
I need your help!
Our customer met the error trouble as follows.
So can you confirm the procedure of Vivado-build("motorkit_build.tcl" that is enclosed)? What is the fixing way of this?
The procedure was brought from  https://github.com/analogdevicesinc/hdl/tree/hdl_2014_r1 .
He builted "hdl-hdl_2014_r1/projects/motor_control" by Vivado 2013.4 to use Building on Vivado( http://wiki.analog.com/resources/fpga/docs/hdl ).
ERROR: Timing Constraints NOT met.
invalid command name "use_this_invalid_command_to_crash"
    while executing
    invoked from within
"if [expr [get_property SLACK [get_timing_paths]] < 0] {
    puts "ERROR: Timing Constraints NOT met."
    (procedure "adi_project_run" line 61)
    invoked from within
"adi_project_run motor_control_zed"
    (file "./system_project.tcl" line 11)
Vivado%
My enclosed "timing_synth.log,timing_impl.log" that were brought from the under of "hdl-hdl_2014_r1/projects/motor_control/zed" show "Slack(VIOLATED)".
Thank you Kaos
