ad9364 no-OS driver run error,Floating point exception
Question asked by east.xie on Apr 23, 2015
Latest reply on Apr 25, 2015 by east.xie
I am working on ad9364 on linux2.6.30, and I am using no-OS driver.
Because AD9364 is used instead of AD9361 the following changes are make to the default_init_param structure:
     - two_rx_two_tx_mode_enable has to be set to 0
     - two_t_two_r_timing_enable has to be set to 0
     --xo_disable_use_ext_refclk_enable has to set 1, because I use ext sine wave generator
but in the run time ,there are often occur some error 'Floating point exception'.   why is the issue, does the no-OS driver bug or the runtime problem?
Calibration TIMEOUT (0x247, 0x2)
Calibration TIMEOUT (0x287, 0x2)
and finally in ad9361_gc_setup   print :@@
ad9361_gc_setup
The following is what console print :
[root@wireless-0945 /mnt]# ./ad9361_generic
ad9361_reset: by GPIO
PRODUCT ID  value: : 0xA
ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
debug: finished  register_clocks(phy)
debug: finished ad9361_init_gain_tables(phy)
ad9361_setup
ad9361_set_dcxo_tune : coarse 8 fine 5920
ad9361_set_trx_clock_chain
ad9361_set_trx_clock_chain: 983040000 245760000 122880000 61440000 30720000 30720000
ad9361_set_trx_clock_chain: 983040000 122880000 122880000 61440000 30720000 30720000
ad9361_bbpll_set_rate: Rate 983040000 Hz Parent Rate 40000000 Hz
ad9361_clk_factor_set_rate: Rate 245759803 Hz Parent Rate 983039215 Hz
ad9361_clk_factor_set_rate: Rate 122879901 Hz Parent Rate 245759803 Hz
ad9361_clk_factor_set_rate: Rate 122879901 Hz Parent Rate 122879901 Hz
ad9361_clk_factor_set_rate: Rate 61439950 Hz Parent Rate 122879901 Hz
ad9361_clk_factor_set_rate: Rate 30719975 Hz Parent Rate 61439950 Hz
ad9361_clk_factor_set_rate: Rate 30719975 Hz Parent Rate 30719975 Hz
ad9361_rssi_setup
ad9361_auxadc_setup
ad9361_rf_port_setup : INPUT_SELECT 0x3
ad9361_pp_port_setup
ad9361_auxdac_setup
ad9361_auxdac_set DAC1 = 0 mV
ad9361_auxdac_set DAC2 = 0 mV
ad9361_auxadc_setup
ad9361_ctrl_outs_setup
ad9361_gpo_setup
ad9361_set_ref_clk_cycles : ref_clk_hz 40000000
ad9361_clk_factor_set_rate: Rate 80000000 Hz Parent Rate 40000000 Hz
ad9361_rfpll_recalc_rate: Parent Rate 80000000 Hz
ad9361_txrx_synth_cp_calib : ref_clk_hz 80000000 : is_tx 0
ad9361_txrx_synth_cp_calib : ref_clk_hz 80000000 : is_tx 1
ad9361_rfpll_set_rate: Rate 1175000000 Hz Parent Rate 80000000 Hz
ad9361_fastlock_prepare: RX Profile 0: Un-Prepare
ad9361_rfpll_vco_init : vco_freq 9400000000 : ref_clk 80000000 : range 2
ad9361_rfpll_vco_init : freq 9269 MHz : index 13
ad9361_load_gt: frequency 2350000000
ad9361_load_gt: frequency 2350000000 (band 1)
ad9361_rfpll_recalc_rate: Parent Rate 20000000 Hz
ad9361_rfpll_set_rate: Rate 1175000000 Hz Parent Rate 40000000 Hz
ad9361_fastlock_prepare: TX Profile 0: Un-Prepare
ad9361_rfpll_vco_init : vco_freq 9400000000 : ref_clk 40000000 : range 0
ad9361_load_mixer_gm_subtable
ad9361_gc_setup
Thanks!
