2147x sport code
Question asked by twilkers Employee on Apr 22, 2015
Latest reply on Apr 23, 2015 by Jithul_Janardhanan
my customer has a problem with his init, can you take a look at it?  thanks, Tim
I tried to use PCG to generate clock for master I2S to transmit data.
The I2S information is as following:
        Fs 8kHz
        32bit
        Bit Clk:  8 * 64 = 512KHz
The external clock is 2.048 Mhz (256 *fs) for PCG.
I found the data on I2S bus (SPORT0A) are not correct. The below is my some codes for the I2S. Please to check these and find some wrong settings. Thanks.
Codes:
//SRU:
    SRU(LOW, PBEN20_I); //extern clock 2.048MHz
    SRU(DAI_PB20_O, PCG_EXTA_I);
    SRU(HIGH, PBEN16_I);
    SRU(DAI_PB20_O, DAI_PB16_I);
    SRU(PCG_CLKA_O, SPORT0_CLK_I);
    SRU(PCG_FSA_O, SPORT0_FS_I);
    SRU (HIGH, PBEN10_I);
SRU(PCG_CLKA_O, DAI_PB10_I);
    SRU (HIGH, PBEN11_I);
SRU(PCG_FSA_O,  DAI_PB11_I);
   SRU (HIGH, PBEN12_I);
   SRU (SPORT0_DA_O, DAI_PB12_I);
//PGC init
   #define DIVCLKA             4
   #define DIVFSA                 256
            *pPCG_CTLA0 = 0;
            *pPCG_CTLB0 = 0;
            // Wait minimum 16 cycles after disable the PCG
            for (n=0; n<16; n++)
                        asm("NOP;");
            *pPCG_CTLA1 |= DIVCLKA | CLKASOURCE  | FSASOURCE ;
            *pPCG_CTLA0 |= DIVFSA | ENFSA | ENCLKA;
//Sport0A init
            TCB_Block_Out0[0] = (((int) TCB_Block_Out1 + 3) & OFFSET_MASK);
            TCB_Block_Out0[3] = (unsigned int) OutBlock_0;
            TCB_Block_Out1[0] = (((int) TCB_Block_Out0 + 3) & OFFSET_MASK);
            TCB_Block_Out1[3] = (unsigned int) OutBlock_1;
            *pSPMCTL0 = 0;
            *pSPCTL0 = 0;
            *pDIV0 = 0;
        for(i=0;i<8;i++) asm("nop;");
            /* Enabling Chaining */
            /* Block A will be filled first */
            //*pCPSP0A = ((unsigned int) TCB_Block_InA + 7) & OFFSET_MASK ;
    *pCPSP0A = (unsigned int)TCB_Block_Out0 - OFFSET + 3;
            *pSPCTL0 = (SPEN_A|    /* Enable Channel A */
                                                SDEN_A| /* Enable Channel A DMA */
                                                SCHEN_A| /* Enable Channel A DMA Chaining */
                                                SLEN32| /* 32-bit word length */
                                                OPMODE| /* Enable I2S Mode*/
                                                MSTR| /*master mode*/
                                                SPTRAN); /* Transmit on enabled channels */
