AD7747 recover from power-down mode
Question asked by Idowu on Apr 15, 2015
Latest reply on Apr 17, 2015 by jcolao
Problem:
I get repeated measurements when I use power-down mode (Measurement does not change). When I don't power-down, the measurements change accordingly, as expected.
Application:
I'm using two AD7747 (CDC) for liquid level sensing. My application is required to minimise power consumption therefore I like to put my AD7747 on power-down mode while waiting for the next measurement cycle. My sample rate is 150ms. I set the CDCs to single-conversion mode or continuous mode before taking a new measurement. And power-down after measurement.
Code fragment:
    // READ CAP SENSOR VALUE
    digitalWrite(SDA_SWITCH_PIN, SENSE_DOWN);
    writeRegister(REGISTER_CONFIGURATION, _BV(5) | _BV(1)); // single conversion mode at 124ms conversion time.
    int cap_down = (int)((float(readValue())/16777215)*16*100);
    writeRegister(REGISTER_CONFIGURATION, _BV(1) | _BV(0)); // power down.
    digitalWrite(SDA_SWITCH_PIN, SENSE_UP);
    int cap_up = (int)((float(readValue())/16777215)*16*100);
Question:
How can I recover from power-down mode? I have tried using delays (for up to 1sec) to ensure the CDCs is fully awake but had no luck.
Any solution to this problem?
Thanks.
