ADV7511 Reference Design on Virtex VC707 not working (HDMI output)
Question asked by bereza on Apr 14, 2015
Latest reply on Jun 4, 2015 by DragosB
I am having trouble to get the reference design for ADV7511 to work properly on a VC707 Board. The only resulotions, which produce a a picture are 1920x1080 (clear) and 1600x900 (noisy). While showing the example picture in these two resolutions, the screen is constantly displaying a message like "false mode. recommended mode is ... 60 Hz" Every other resolution results in a black screen.
The funny thing is that I tested the corresponding reference design on a zc706 board and it worked without any problems with the same screen and cable. Every resolution was possible and the screen didn't show the message "false mode. ..."
How can I get the reference design to work? Is there somebody who experienced the same problem? How could it be solved?
Here is what I used:
            At the moment I only have XIlinx 14.6 tools available. In the adv wiki there are links to files for Vivado Design Suite,   but I found the link above, which seems to be the right one for 14.6.
I tried everything possible. First I synthsized the design myself. There was a message that 2 timing constrains were not met. I thought this could be the problem so I used the provided bitstream: system.bit This didn't make things better. I then decided try the evaluation script As I am using linux, I simply typed the commands from evaluate.bat myself into XMD. This had the same result. I used the same sources for the zc706 and everything worked fine.
I borrowed a second vc707 to exclude a malfunction of the board and there were the same problems. Also I wanted to add the output i get in the console.  As you might notice I had to plug the HDMI cable out and in to receive the EDID information, which is also odd. Anyway, here is the output:
  ADI HDMI Trasmitter Application Ver R1.1.1
  HDMI-TX:  ADV7511 Rev 0x14
  Created:  Apr 10 2015 At 11:02:55
Mute audio and video.
Errorcode: APP: Driver Enabled
HPD changed to HI
MSEN changed to HI
APP: Changed system mode to Transmitter
Un-mute audio and video.
HPD changed to LOW
MSEN changed to LOW
APP: Changed system mode to Disconnected
HPD changed to HI
MSEN changed to HI
A new EDID segment was read.
DVI device.
------------------------- EDID BLOCK 0 -------------------------
Edid Version 1.3
Mon Timing:
    Pixel clock = 108.0 MHz
    H Active    = 1280
    V Active    = 1024
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Freq:
    Min V Freq = 56 Hz
    Max V Freq = 75 Hz
    Min H Freq = 30 KHz
    Max H Freq = 81 KHz
Mon Name:   SyncMaster
Mon Serial: HMCQ848531
Edid extensions blocks: 0
########################### EDID END ###########################
Resolution was changed to 1600x900
Resolution was changed to 1920x1080
Resolution was changed to 640x480
Resolution was changed to 800x600
Resolution was changed to 1280x720
Thank you in advance,
Bereza
