AD7476 Interfacing Code in Verilog
Question asked by SuvanB on Apr 8, 2015
Latest reply on Apr 20, 2015 by jcolao
    I am trying to use a PMOD AD1 from digilent, which has 2 AD7476s. I am using it with a Zedboard and need some kind of basic reference code for interfacing the ADC. I have posted my code below. I can see it converting the data, on the DataA pin digital (sequence of 1s and 0s). However, its not able to use the data to make a decision on the PWM signal of a buck converter. (module pwm, posted below the ADC7476 module).
module ADC7476_Int(clk,Sclk,CSb,DinA,DinB,DataA,DataB);
input clk;
output Sclk;
output reg CSb;
input DinA,DinB;
output reg signed[11:0] DataA,DataB;
reg [11:0] SDataA, SDataB; //Shift registers for serial read
reg [8:0] c=0;
reg flag=0;
always @(posedge clk)
begin
   if (c>=264)  // c counts 2.6uS, 379 kSpS. Each c increment is 20 nS.
   c <= 0;
     else
    c<=c+1;
  end
  assign Sclk = c[3]; //There are 66 Sclk cycles in one data acquisition. (fSclk = 6.25 MHz, since highest allowed is 12 MHz)
  begin
       case(c)
     0 : begin  // tQUIET-t1 = 20 nS
     CSb <= 0;
     flag <= 0;
    end
      2 : begin //t1 = 40 nS
            CSb <= 1;
            flag <= 0;
           end
        6 : begin //4 preceding zeros = 640ns
            CSb <= 0;
            flag <= 0;
  end
      70 : begin // tCONVERT : DB11-DB0 -> 1920ns + t8 (20 ns) = 1940 ns
         CSb <= 0;
         flag <= 1;
         end
   264 : begin
      CSb <= 0;
      flag <= 0;
  DataA <= SDataA;// actual data in SDataA - 4 preceding zeros
  DataB <= SDataB;
  end
        default: begin
       CSb <= CSb;
       flag <= flag;
   end
    endcase
   end
   always @(negedge Sclk)
  begin
     SDataA <= {SDataA[10:0],(flag & DinA)};// Serial read and shift, only when flag is high.
  SDataB <= {SDataB[10:0],(flag & DinB)};
  end
  endmodule
module pwm (clk_pin,clk_s,Su,Sl,Si,CSb,Sclk,DinA,DinB);
input clk_pin;
input DinA,DinB;
output reg clk_s, Si;
output Su,Sl;
output CSb,Sclk;
wire signed [11:0] DataA, DataB;
reg wu,wl;
dead_time inst1(.wu(wu),.wl(wl),.clk(clk_pin),.reset(1),.Su(Su),.Sl(Sl));
ADC7476_Int inst2(.clk(clk_pin),.Sclk(Sclk),.CSb(CSb),.DinA(DinA),.DinB(DinB),.DataA(DataA),.DataB(DataB));
reg [14:0] count = 0;
integer count_max=1000, duty=900;
always @(posedge CSb) //Control Code
begin
if (DataA<=2048)
duty = 700;
else
duty = 500;
end
always @(posedge clk_pin)
begin
if (count>=0 && count<=duty)
begin
clk_s <= 0;
count <=count +1;
end
else if (count>duty && count < count_max)
begin
clk_s <= 1;
count <= count + 1;
end
else
begin
clk_s <= clk_s;
count <= 0;
end
end
begin
wu<=clk_s;
wl<=~clk_s;
end
endmodule
