Question about file write on Sharc DSP
Question asked by Quiwi on Apr 3, 2015
Latest reply on May 27, 2015 by jobo23
With ADSP21489 EZ-board, in the example project "21489 AD1939 C Block-Based Talkthru 48 or 96 kHz"
I want to write the input data to a txt file, so I added the following codes in the function "void process_audioBlocks()"
     FILE* fp;
     memcopy(fBlockA.Rx_L1, fBlockA.Tx_L1, NUM_SAMPLES);
      memcopy(fBlockA.Rx_R1, fBlockA.Tx_R1, NUM_SAMPLES);
     fopen("D:\\test.txt","w");
     fprintf(fp,"%.1f",fBlockA.Rx_L1); //just for testing
     fclose(fp);
However, there was no output of DAC after I added these codes. The program stuck in ProcessingTooLong();
I moved the codes to the function handleCodecData(), aslo no output.
Need help for this problem, thanks!
