Can't create RX buffer using Libiio and ad_adc driver
Question asked by njp on Apr 1, 2015
Latest reply on Apr 2, 2015 by njp
I'm having issues creating a buffer using Libiio and the ad_adc driver (configured for AD7980).  The ad_adc is showing up as an IIO device with a buffer (enable and length) and the scan_elements. The function iio_context_find_device works fine, but when I call iio_device_create_buffer I get an error.
I have tracked the error to the function "iio_device_get_sample_size_mask()" in device.c of Libiio. I put the code snippet at the bottom of the post. My issue is:
  • dev->nb_channels = 1
    • This is what I want
  • *mask = 0
    • I'm not sure what the value is supposed to be, but with it being 0 it hits the continue and then size is returned as 0
I haven't yet tracked this down, but I'm assuming it's something missing in ad_adc.c. I haven't had this issue when using the ad9361.c driver.
Thanks!
ssize_t iio_device_get_sample_size_mask(const struct iio_device *dev,
        uint32_t *mask, size_t words)
    ssize_t size = 0;
    unsigned int i;
    if (words != (dev->nb_channels + 31) / 32) {
        return -EINVAL;
    for (i = 0; i < dev->nb_channels; i++) {
        const struct iio_channel *chn = dev->channels[i];
        unsigned int length = chn->format.length / 8;
        if (chn->index < 0) {
            break;
        if (!TEST_BIT(mask, chn->index)) {
            continue;
        if (size % length) {
            size += 2 * length - (size % length);
        else {
            size += length;
    return size;
