ADV7611 image dislocation
Question asked by YangXL on Mar 31, 2015
Latest reply on Apr 9, 2015 by mattp
Dear all,
We have developed a board, use ADV7611 to receive 1080P30 hdmi signal,output YUV444 to DM368.
I capture the YUV singal.
But the image left side dislocation, the dislocation width is about 88 pixel.
I also connet the hdmi signal source to the TV. My capture YUV image scene is less than the TV on the right side.
I try bleow point:
1.I change the capture start position of VS ,HS.
2.I change the capture input size.
3.I change the polariity of the ADV7611 DE,VS,HS.
4.I don't insert AV codes
But I can't solve the dislocation on the left side, also can't see the lessen image scene on the right side compare with TV.
Can some one help me?
Best,
Yang
The image as below:
my register setting as below:
:6-1f Port A, 1080p YPrPb 444 in, RGB 444 out, Through HDMI VIC[16,31,32]:
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F5 ; Auto CSC, RGB out, Set op_656 bit
98 03 80; 16 bit ITU-656 SDR mode
98 05 2C ; insert AV Codes
98 06 A2 ; Invert VS,HS pins
98 0B 44 ; Power up part
98 0C 42 ; Power up part
98 14 3F ; Max Drive Strength
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL enable
44 BA 01 ; Set HDMI FreeRun
64 40 81 ; Disable HDCP 1.1 features
68 9B 03 ; ADI recommended setting
68 C1 01 ; ADI recommended setting
68 C2 01 ; ADI recommended setting
68 C3 01 ; ADI recommended setting
68 C4 01 ; ADI recommended setting
68 C5 01 ; ADI recommended setting
68 C6 01 ; ADI recommended setting
68 C7 01 ; ADI recommended setting
68 C8 01 ; ADI recommended setting
68 C9 01 ; ADI recommended setting
68 CA 01 ; ADI recommended setting
68 CB 01 ; ADI recommended setting
68 CC 01 ; ADI recommended setting
68 00 00 ; Set HDMI Input Port A
68 83 FE ; Enable clock terminator for port A
68 6F 08 ; ADI recommended setting
68 85 1F ; ADI recommended setting
68 87 70 ; ADI recommended setting
68 8D 04 ; LFG
68 8E 1E ; HFG
68 1A 8A ; unmute audio
68 57 DA ; ADI recommended setting
68 58 01 ; ADI recommended setting
68 75 10 ; DDC drive strength
