ADXL362 data always zero!!
Question asked by Awrak on Mar 26, 2015
Latest reply on Apr 3, 2015 by neilzhao
I am trying to communicate with ADXL362 via SPI, the controller I'm using is PIC32MX150F128B. I'm trying to get the device ID but I'm getting all zeroes, I've tried reading X, Y & Z values but I'm still unlucky. My SPI loopback is working, so I've not been able to pin point the problem yet. My SPI baud rate is 2MHz, here is ADXL362 read and write code.
UINT8 ADXL362_Read(UINT8 reg_add){
    UINT8 u8_spi_read_data;
    UINT dummy;
    LATBbits.LATB15 = 0;                                                             // select slave device
    if(!TxBufFullSPI1()){WriteSPI1(SPI_READ_REGISTER_CMD);} // write adxl362 read-command to begin transmission
    while( !SPI1STATbits.SPIRBF);                                               // wait for transfer to complete
    dummy = SPI1BUF;        // Read the buffer to clear it
    if(!TxBufFullSPI1()){WriteSPI1(reg_add);}
    if(SPI1STATbits.SPITBE) {SPI1BUF = 0x00;}                           // Transfer some dummy value
    u8_spi_read_data = SPI1BUF;
    LATBbits.LATB15 = 1;                                                             // release slave device
    return u8_spi_read_data;
BOOL ADXL362_Write(UINT8 reg_add,UINT8 reg_value){
    UINT dummy;
    SPI1BUF = SPI_WRITE_REGISTER_CMD;               // write adxl362 write-command to begin transmission
    SPI1BUF = reg_add;                                                  // write the 8-bit address
    SPI1BUF = reg_value;                                                // write the 8-bit data
As per the ADXL362 data sheet I'm writing the Write/Read command first then the register address followed by the data if it is a write or a dummy value if it is a read. I've followed all the instructions as per the PIC and ADXL362 data sheet.
Any help is really appreciated.
Thanks!
