ADG707 offset leakage current?
Question asked by Reson8r on Mar 23, 2015
Latest reply on Mar 26, 2015 by Stephen_Nugent
The ADG707 has an ON channel leakage spec (ID, IS ON) of +/- 1 nA max over temp.  What would be the "offset leakage", or difference in leakage, between common switch points DA and DB if they are at the same voltage?  You wouldn't expect one to be at +1 nA and the other at -1nA if they're at the same voltage, would you?  It seems like the offset current with both pins at the same voltage would approach zero.
Thanks for any help,
Gerrit
