ADV7619 HDMI PC
Question asked by giampybg on Mar 22, 2015
Latest reply on Jun 9, 2015 by mattp
Hi, I've made a board with ADV7619 that accepts 2 HDMI input and converts it in LVDS output (24 bit 4:4:4 RGB).
I've tested this board with HDMI input from a uQ7 board and this works perfectly with the script configuration that I found on the design support page.
But if I use the HDMI from a PC this doesn't work.
Which is the correct script configuration for that input?
This is the configuration that I've used
:02-06 720p,1080i,1080p In - 24-bit RGB 444 Out:
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
68 C0 03 ; ADI Required Write
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F7 ; Auto CSC, RGB out, Set op_656 bit
98 03 40 ; 24 bit SDR 444 Mode 0
98 05 28 ; AV Codes Off
98 06 A6 ; Invert VS,HS pins
98 0C 42 ; Power up part
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL MUX enable
44 BA 01 ; Set HDMI FreeRun
44 6C 00 ; Required ADI write
64 40 81 ; Disable HDCP 1.1 features
4C B5 01 ; Setting MCLK to 256Fs
68 C0 03 ; ADI Required write
68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
68 02 03 ; ALL BG Ports enabled
68 03 98 ; ADI Required Write
68 10 A5 ; ADI Required Write
68 1B 08 ; ADI Required Write
68 45 04 ; ADI Required Write
68 97 C0 ; ADI Required Write
68 3D 10 ; ADI Required Write
68 3E 69 ; ADI Required Write
68 3F 46 ; ADI Required Write
68 4E FE ; ADI Required Write
68 4F 08 ; ADI Required Write
68 50 00 ; ADI Required Write
68 57 A3 ; ADI Required Write
68 58 07 ; ADI Required Write
68 6F 08 ; ADI Required Write
68 83 FC ; Enable clock terminators for port A & B
68 84 03 ; ADI Required Write
68 85 10 ; ADI Required Write
68 86 9B ; ADI Required Write
68 89 03 ; ADI Required Write
68 9B 03 ; ADI Required Write
68 93 03 ; ADI Required Write
68 5A 80 ; ADI Required Write
68 9C 80 ; ADI Required Write
68 9C C0 ; ADI Required Write
68 9C 00 ; ADI Required Write
Thanks for your support.
