ADV7393 PAL Output Problem
Question asked by mrelectroniceng on Mar 19, 2015
Latest reply on Mar 20, 2015 by PaulS
Dear Community,
We have designed a PCB to give PAL output. The board is connected to a FPGA module so I can modify the necessary inputs to ADV7393.
However, we have a problem. We have two televisions with the same brand but different model. One of the TVs gives very good output. However, the other TV rarely gives the true output. When I give internally generated test pattern to the TV, it shows perfectly the vertical colored frame. Probably, the input (digital waveform) which I provide is not perfectly suitable for ADV7393.
I provide 27 MHz clock to the ADV7393. The frame is composed of 625 lines as in Figure 112. (SD Timing Mode 2, Slave Option, PAL) (in the datasheet). The line is composed of 1536 cycles ((Y and CrCb) x 768). HSYNC and VSYNC pulse width is one clock cycle (I also increased the pulse width but it did not work).
I tried to explain as detailed as possible. What could be the problem?
Thank you for your time.
Configuration for the internally generated test pattern:
Register          Value
0x17               0x02
0x00               0x1c
0x80               0x11
0x82               0xcb
0x84               0x40
0x8c               0xcb
0x8d               0x8a
0x8e               0x09
0x8f               0x2a
Configuration for the designed system:
Register          Value
0x17               0x02
0x00               0x1c
0x01               0x00
0x80               0x11
0x82               0xc3
0x88               0x10
0x8a               0x0c
0x8c               0xcb
0x8d               0x8a
0x8e               0x09
0x8f                0x2a
