ADE7880 shunt resistor
Question asked by r.simoncelli@antgroup.it on Mar 16, 2015
Latest reply on Mar 20, 2015 by dlath
Hi
A question concerning the shunt resistor.
I'm using a board designed around a ADE7880 chip. In several AD appnotes I found that a "center-tapped" burden resistor is suggested.
( and the evaluation board schematic shows the same solution).
We need to measure high currents and we use standard CT transformers ( for instance 200/5 or 50/5) that give 5Amps when the load current is at full scale.
That means that the shunt resistor can't be a small smd (or even pth) component directly placed on the pcb.
Our shunt resistors are usually 0.1ohm / 5W elements connected directly on the CT.
My question is: have you any suggestion? Is there any trick that I should use? (pheraps.. Is there any advantage in leaving an additional 50+50ohm center- tapped on board... that give some reference to gnd?)
Thankyou
Roberto
