AD7606-6 conversion result
Question asked by deltanick on Mar 11, 2015
Latest reply on Mar 12, 2015 by deltanick
Dear All,
I'm using the board Eval-ad7606-6EDZ to acquire analog signal, this is connect with a dsPIC33 by using the serial interface.
I need an input range of +-5V.
This is the connection of the pin
SER/!PAR -> Vdrive
RANGE -> GND
REFSEL -> Vdrive
DoutA ->  dsPIC
CONVST -> dsPIC
SCLK -> dsPIC
!CS -> dsPIC
BUSY ->dsPIC
STBY -> Vdrive
OS0 -> GND
OS1 -> GND
OS2 -> GND
After power-up the dsPIC send a reset signal to the converter.
I have a problem with the conversion result. When the input voltage is larger than +-2.5V,  the most significant bit of the result goes high, thus the value change the sign. For example if the input is 3V, the conversion result is -2.
Moreover, I have try with the input range of +-10V, RANGE -> Vdrive. In this way the problem is when the input is larger than +-5V, thus the problem persist.  Whith the +-10V range I used 6553.6 as conversion factor.
Which is the possible problem?
Thank you for your consideration.
Best regards.
