ADXL375 offset register/Shock Threshold
Question asked by vindhyachal.takniki@gmail.com on Mar 11, 2015
Latest reply on Mar 20, 2015 by venkat
1. I have to write offset register values in adxl375.
On putting device so that x = 0g , y = 0g & z = 1g
I get output valuesfrom adxl375 as; xreg = -14 , yreg = 15 & zreg = +34
Now what should I write to offset registers of adxl375;
a). Is it invert of each value
b). I read AN-1077 describing offset regsiter value of adxl345, it had mention values as
X_CALIB = –(OUTPUT (X) ÷ 4)
Y_CALIB = –(OUTPUT (Y) ÷ 4)
Z_CALIB = –((OUTPUT (Z) – 256) ÷ 4)
c). which of above I should choose
2. I had to enable double/single threshold interrupt.
I had read that this register is 780mg/LSB.
Also datasheet says:
"The SHOCK_AXES register specifies the participation of each of the three axes in single shock/double shock detection."
How does it correlates to values in THRESH_SHOCK register.
Is it
THRESH_SHOCK   =  sqrt( (dataX * dataX) + (dataX * dataX)  + (dataZ * dataZ)   )
