PPI and debugging via VisualDSP++ thru JTAG
Question asked by tcmichals on Nov 17, 2010
Latest reply on Nov 23, 2010 by tcmichals
Problem: Resuming execution after software or HW break point the PPI DMA keeps interrupting the processor and never serviced.  If I don't have any breakpoints  everything works great!!!
General flow of the code:
- BF527
- Start VDK
- call adi_ssl_Init
- set up TCP/IP stack
- setup serial port
- setup flash drivers (SPI)
- setup PPI driver
     - using exernal frame sync
     - 100Khz/1024  ISR rate
- breakpoint in ISR of the PPI call back, or just stop and resume
Result:
SIC_ISR0 is 00208040 so the _adi_init_NestingISR is called due to DMA0 has issued an ISR
adi_dma.c DataHandler ISR
- Also, since the PPI is driven via external clock etc. this is still happening while the debugger is stopped
static ADI_INT_HANDLER(DataHandler) // DMA handler
    unsigned int                i;                  // counter
    ADI_INT_HANDLER_RESULT      Result;             // result
    ADI_DMA_CHANNEL             *pChannel;          // pointer to the channel we're working on
    u32                         AssertedFlag;       // flag indicating whether or not the channel has an interrupt asserted
// avoid casts
    pChannel = (ADI_DMA_CHANNEL *)ClientArg;
    Result = ADI_INT_RESULT_NOT_PROCESSED;
    // assume the channel is not interrupting
    AssertedFlag = FALSE;
    // IF (this channel is asserting an interrupt cause DMA_DONE is set)
    if (pChannel->IRQStatus->b_DMA_DONE == ADI_DMA_DONE_DONE) { <----HERE the b_DMA_DONE is 0 but it is interrupting
        // clear the interrupt (need to do this funky thing with the casts cause
        // we get a DMA error if we try and write to RO bits)
        *(u16 *)pChannel->IRQStatus = ADI_DMA_DONE_DONE;
        // set flag to show this channel is interrupting
        AssertedFlag = TRUE;
    // ENDIF
If I go and turn off the PPI using PPI_CONTROL register, code starts executing...
I see that the PPI Status is 0x1000 I guess this would case a PPI DMA interrupt also? I that it cleared the SIC..
I cannot live without the software debugger !!!
