EZKIT-21469 Push Button interrupt
Question asked by LordBIX on Feb 28, 2015
Latest reply on Jun 7, 2015 by LordBIX
Dears,
i am having a problem, that my pushbutton interrupt for DAI connected buttons are only called once. So its working one time
How i get the the interrupt back in the mode to be able to be triggered for input?
I have attached the code..
Thank you for your help!
  /* pin assignments in SRU_PIN3 (Group D) */
  SRU(LOW,DAI_PB19_I); /* assign pin buffer 19 low so it is an input */
  SRU(LOW,DAI_PB20_I); /* assign pin buffer 20 low so it is an input */
  /* route MISCA signals in SRU_EXT_MISCA (Group E) */
    SRU(DAI_PB19_O,MISCA1_I); /* route so that DAI pin buffer 19 connects to MISCA1 */
    SRU(DAI_PB20_O,MISCA2_I); /* route so that DAI pin buffer 20 connects to MISCA2 */
    /* pin buffer disable in SRU_PINEN0 (Group F) */
    SRU(LOW,PBEN19_I); /* assign pin 19 low so it is an input */
  SRU(LOW,PBEN20_I); /* assign pin 20 low so it is an input */
  /* unmask individual interrupts */
  (*pDAI_IRPTL_PRI) = (SRU_EXTMISCA1_INT | SRU_EXTMISCA2_INT);
  /* make sure interrupts latch on the rising edge */
    (*pDAI_IRPTL_RE) = (SRU_EXTMISCA1_INT | SRU_EXTMISCA2_INT);
    //(*pDAI_IRPTL_FE) = (SRU_EXTMISCA1_INT | SRU_EXTMISCA2_INT);
  /* setup the IRQ pins to use the pushbuttons */
  (*pSYSCTL) |= (IRQ1EN | IRQ2EN);
  sysreg_bit_set(sysreg_MODE2, (IRQ1E | IRQ2E) );
  sysreg_bit_clr(sysreg_IRPTL, (IRQ1I | IRQ2I) );
  /* enable IRQ interrupts and make DAI interrupts high priority */
  sysreg_bit_set(sysreg_IMASK, (IRQ1I | IRQ2I | DAIHI) );
  sysreg_bit_set(sysreg_MODE1, IRPTEN ); /* enable global interrupts */
  /* register the interrut handlers */
  interrupt(SIG_DAIH,SW10_SW11_DAI_handler);
  interrupt(SIG_IRQ1,SW8_IRQ1_handler);
    interrupt(SIG_IRQ2,SW9_IRQ2_handler);
void SW10_SW11_DAI_handler(int sig_int)
  int iTest = 0; /* flag to indicate which button was pushed */
  /* read the latch register which also clears the latched interrupt */
  iTest = (*pDAI_IRPTL_H);
  bypass_IIR=!bypass_IIR;
  /* if sw10 */
  if(SRU_EXTMISCA1_INT == iTest)
  // switch 10 code
// bypass_IIR=!bypass_IIR;
  /* else if sw11 */
  else if(SRU_EXTMISCA2_INT == iTest)
  // switch 11 code
