AD9361 parameters
Question asked by TothR on Feb 27, 2015
Latest reply on Mar 10, 2015 by mhennerich
I have a question in connection of the AD9361 chip. I have found sourcefiles on analogdevice github, and I would like to get more information about the parameters in the AD9361: sw/main.c Source File
Could you please send me a link, where can I find more information about what and how  these parameters affect?
There is a 6 element array among the parameters:
{983040000, 245760000, 122880000, 61440000, 30720000, 30720000},//uint32_t rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
Which clock drives what?
The parameters:
  82 AD9361_InitParam default_init_param = {
  83   /* Identification number */
  84  0,  //id_no;
  85   /* Reference Clock */
  86  40000000UL,  //reference_clk_rate
  87   /* Base Configuration */
  88  1,  //two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
  89  1,  //frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
  90  0,  //tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
  91  0,  //tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
  92  0,  //tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
  93  0,  //rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
  94  0,  //rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
  95  0,  //tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
  96  0,  //external_rx_lo_enable *** adi,external-rx-lo-enable
  97  0,  //external_tx_lo_enable *** adi,external-tx-lo-enable
  98  5,  //dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
  99  6,  //dc_offset_attenuation_high_range *** adi,dc-offset-tracking-update-event-mask
  100  5,  //dc_offset_attenuation_low_range *** adi,dc-offset-tracking-update-event-mask
  101  0x28,  //dc_offset_count_high_range *** adi,dc-offset-tracking-update-event-mask
  102  0x32,  //dc_offset_count_low_range *** adi,dc-offset-tracking-update-event-mask
  103  0,  //tdd_use_fdd_vco_tables_enable *** adi,tdd-use-fdd-vco-tables-enable
  104  0,  //split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
  105  MAX_SYNTH_FREF, //trx_synthesizer_target_fref_overwrite_hz *** adi,trx-synthesizer-target-fref-overwrite-hz
  106  0,  // qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable
  107   /* ENSM Control */
  108  0,  //ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
  109  0,  //ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
  110   /* LO Control */
  111  2400000000UL,  //rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz
  112  2400000000UL,  //tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
  113   /* Rate & BW Control */
  114  {983040000, 245760000, 122880000, 61440000, 30720000, 30720000},//uint32_t rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
  115  {983040000, 122880000, 122880000, 61440000, 30720000, 30720000},//uint32_t tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
  116  18000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
  117  18000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
  118   /* RF Port Control */
  119  0,  //rx_rf_port_input_select *** adi,rx-rf-port-input-select
  120  0,  //tx_rf_port_input_select *** adi,tx-rf-port-input-select
  121   /* TX Attenuation Control */
  122  10000,  //tx_attenuation_mdB *** adi,tx-attenuation-mdB
  123  0,  //update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
  124   /* Reference Clock Control */
  125  0,  //xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable
  126  {8, 5920},  //dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
  127  0,  //clk_output_mode_select *** adi,clk-output-mode-select
  128   /* Gain Control */
  129  2,  //gc_rx1_mode *** adi,gc-rx1-mode
  130  2,  //gc_rx2_mode *** adi,gc-rx2-mode
  131  58,  //gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
  132  4,  //gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
  133  47,  //gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
  134  8192,  //gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
  135  0,  //gc_dig_gain_enable *** adi,gc-dig-gain-enable
  136  800,  //gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh
  137  704,  //gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh
  138  24,  //gc_low_power_thresh *** adi,gc-low-power-thresh
  139  15,  //gc_max_dig_gain *** adi,gc-max-dig-gain
  140   /* Gain MGC Control */
  141  2,  //mgc_dec_gain_step *** adi,mgc-dec-gain-step
  142  2,  //mgc_inc_gain_step *** adi,mgc-inc-gain-step
  143  0,  //mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
  144  0,  //mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
  145  0,  //mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
  146   /* Gain AGC Control */
  147  10,  //agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
  148  2,  //agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
  149  0,  //agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
  150  10,  //agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
  151  4,  //agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
  152  3,  //agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
  153  1000,  // agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
  154  0,  //agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
  155  0,  //agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
  156  10,  //agc_inner_thresh_high *** adi,agc-inner-thresh-high
  157  1,  //agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
  158  12,  //agc_inner_thresh_low *** adi,agc-inner-thresh-low
  159  1,  //agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
  160  10,  //agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
  161  2,  //agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
  162  10,  //agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
  163  5,  //agc_outer_thresh_high *** adi,agc-outer-thresh-high
  164  2,  //agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
  165  18,  //agc_outer_thresh_low *** adi,agc-outer-thresh-low
  166  2,  //agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
  167  1,  //agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
  168  0,  //agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
  169   /* Fast AGC */
  170  64,  //fagc_dec_pow_measuremnt_duration *** adi,fagc-dec-pow-measurement-duration
  171  260,  //fagc_state_wait_time_ns *** adi,fagc-state-wait-time-ns
  172   /* Fast AGC - Low Power */
  173  0,  //fagc_allow_agc_gain_increase *** adi,fagc-allow-agc-gain-increase-enable
  174  5,  //fagc_lp_thresh_increment_time *** adi,fagc-lp-thresh-increment-time
  175  1,  //fagc_lp_thresh_increment_steps *** adi,fagc-lp-thresh-increment-steps
  176   /* Fast AGC - Lock Level */
  177  10,  //fagc_lock_level *** adi,fagc-lock-level */
  178  1,  //fagc_lock_level_lmt_gain_increase_en *** adi,fagc-lock-level-lmt-gain-increase-enable
  179  5,  //fagc_lock_level_gain_increase_upper_limit *** adi,fagc-lock-level-gain-increase-upper-limit
  180   /* Fast AGC - Peak Detectors and Final Settling */
  181  1,  //fagc_lpf_final_settling_steps *** adi,fagc-lpf-final-settling-steps
  182  1,  //fagc_lmt_final_settling_steps *** adi,fagc-lmt-final-settling-steps
  183  3,  //fagc_final_overrange_count *** adi,fagc-final-overrange-count
  184   /* Fast AGC - Final Power Test */
  185  0,  //fagc_gain_increase_after_gain_lock_en *** adi,fagc-gain-increase-after-gain-lock-enable
  186   /* Fast AGC - Unlocking the Gain */
  187   /* 0 = MAX Gain, 1 = Optimized Gain, 2 = Set Gain */
  188  0,  //fagc_gain_index_type_after_exit_rx_mode *** adi,fagc-gain-index-type-after-exit-rx-mode
  189  1,  //fagc_use_last_lock_level_for_set_gain_en *** adi,fagc-use-last-lock-level-for-set-gain-enable
  190  1,  //fagc_rst_gla_stronger_sig_thresh_exceeded_en *** adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
  191  5,  //fagc_optimized_gain_offset *** adi,fagc-optimized-gain-offset
  192  10,  //fagc_rst_gla_stronger_sig_thresh_above_ll *** adi,fagc-rst-gla-stronger-sig-thresh-above-ll
  193  1,  //fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en *** adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
  194  1,  //fagc_rst_gla_engergy_lost_goto_optim_gain_en *** adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
  195  10,  //fagc_rst_gla_engergy_lost_sig_thresh_below_ll *** adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
  196  8,  //fagc_energy_lost_stronger_sig_gain_lock_exit_cnt *** adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
  197  1,  //fagc_rst_gla_large_adc_overload_en *** adi,fagc-rst-gla-large-adc-overload-enable
  198  1,  //fagc_rst_gla_large_lmt_overload_en *** adi,fagc-rst-gla-large-lmt-overload-enable
  199  0,  //fagc_rst_gla_en_agc_pulled_high_en *** adi,fagc-rst-gla-en-agc-pulled-high-enable
  200  0,  //fagc_rst_gla_if_en_agc_pulled_high_mode *** adi,fagc-rst-gla-if-en-agc-pulled-high-mode
  201  64,  //fagc_power_measurement_duration_in_state5 *** adi,fagc-power-measurement-duration-in-state5
  202   /* RSSI Control */
  203  1,  //rssi_delay *** adi,rssi-delay
  204  1000,  //rssi_duration *** adi,rssi-duration
  205  3,  //rssi_restart_mode *** adi,rssi-restart-mode
  206  0,  //rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
  207  1,  //rssi_wait *** adi,rssi-wait
  208   /* Aux ADC Control */
  209  256,  //aux_adc_decimation *** adi,aux-adc-decimation
  210  40000000UL,  //aux_adc_rate *** adi,aux-adc-rate
  211   /* AuxDAC Control */
  212  1,  //aux_dac_manual_mode_enable *** adi,aux-dac-manual-mode-enable
  213  0,  //aux_dac1_default_value_mV *** adi,aux-dac1-default-value-mV
  214  0,  //aux_dac1_active_in_rx_enable *** adi,aux-dac1-active-in-rx-enable
  215  0,  //aux_dac1_active_in_tx_enable *** adi,aux-dac1-active-in-tx-enable
  216  0,  //aux_dac1_active_in_alert_enable *** adi,aux-dac1-active-in-alert-enable
  217  0,  //aux_dac1_rx_delay_us *** adi,aux-dac1-rx-delay-us
  218  0,  //aux_dac1_tx_delay_us *** adi,aux-dac1-tx-delay-us
  219  0,  //aux_dac2_default_value_mV *** adi,aux-dac2-default-value-mV
  220  0,  //aux_dac2_active_in_rx_enable *** adi,aux-dac2-active-in-rx-enable
  221  0,  //aux_dac2_active_in_tx_enable *** adi,aux-dac2-active-in-tx-enable
  222  0,  //aux_dac2_active_in_alert_enable *** adi,aux-dac2-active-in-alert-enable
  223  0,  //aux_dac2_rx_delay_us *** adi,aux-dac2-rx-delay-us
  224  0,  //aux_dac2_tx_delay_us *** adi,aux-dac2-tx-delay-us
  225   /* Temperature Sensor Control */
  226  256,  //temp_sense_decimation *** adi,temp-sense-decimation
  227  1000,  //temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
  228  0xCE,  //temp_sense_offset_signed *** adi,temp-sense-offset-signed
  229  1,  //temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
  230   /* Control Out Setup */
  231  0xFF,  //ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
  232  0,  //ctrl_outs_index *** adi,ctrl-outs-index
  233   /* External LNA Control */
  234  0,  //elna_settling_delay_ns *** adi,elna-settling-delay-ns
  235  0,  //elna_gain_mdB *** adi,elna-gain-mdB
  236  0,  //elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
  237  0,  //elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
  238  0,  //elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
  239   /* Digital Interface Control */
  240  1,  //pp_tx_swap_enable *** adi,pp-tx-swap-enable
  241  1,  //pp_rx_swap_enable *** adi,pp-rx-swap-enable
  242  0,  //tx_channel_swap_enable *** adi,tx-channel-swap-enable
  243  0,  //rx_channel_swap_enable *** adi,rx-channel-swap-enable
  244  1,  //rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
  245  0,  //two_t_two_r_timing_enable *** adi,2t2r-timing-enable
  246  0,  //invert_data_bus_enable *** adi,invert-data-bus-enable
  247  0,  //invert_data_clk_enable *** adi,invert-data-clk-enable
  248  0,  //fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
  249  0,  //invert_rx_frame_enable *** adi,invert-rx-frame-enable
  250  0,  //fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
  251  0,  //swap_ports_enable *** adi,swap-ports-enable
  252  0,  //single_data_rate_enable *** adi,single-data-rate-enable
  253  1,  //lvds_mode_enable *** adi,lvds-mode-enable
  254  0,  //half_duplex_mode_enable *** adi,half-duplex-mode-enable
  255  0,  //single_port_mode_enable *** adi,single-port-mode-enable
  256  0,  //full_port_enable *** adi,full-port-enable
  257  0,  //full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
  258  0,  //delay_rx_data *** adi,delay-rx-data
  259  0,  //rx_data_clock_delay *** adi,rx-data-clock-delay
  260  4,  //rx_data_delay *** adi,rx-data-delay
  261  7,  //tx_fb_clock_delay *** adi,tx-fb-clock-delay
  262  0,  //tx_data_delay *** adi,tx-data-delay
  263  150,  //lvds_bias_mV *** adi,lvds-bias-mV
  264  1,  //lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
  265  0,  //rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable
  266   /* Tx Monitor Control */
  267  37000,  //low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh
  268  0,  //low_gain_dB *** adi,txmon-low-gain
  269  24,  //high_gain_dB *** adi,txmon-high-gain
  270  0,  //tx_mon_track_en *** adi,txmon-dc-tracking-enable
  271  0,  //one_shot_mode_en *** adi,txmon-one-shot-mode-enable
  272  511,  //tx_mon_delay *** adi,txmon-delay
  273  8192,  //tx_mon_duration *** adi,txmon-duration
  274  2,  //tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain
  275  2,  //tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain
  276  48,  //tx1_mon_lo_cm *** adi,txmon-1-lo-cm
  277  48,  //tx2_mon_lo_cm *** adi,txmon-2-lo-cm
  278   /* GPIO definitions */
  279  -1,  //gpio_resetb; /* reset-gpios */
  280   /* MCS Sync */
  281  -1,  //gpio_sync; /* sync-gpios */
  282  -1,  //gpio_cal_sw1; /* cal-sw1-gpios */
  283  -1  //gpio_cal_sw2; /* cal-sw2-gpios */
  284 };
Kind Regards,
Richard
