how to realize BF609 width capture based on CCES1.0.2.0?
Question asked by wxlwwxlw on Feb 27, 2015
Latest reply on Apr 27, 2015 by wxlwwxlw
Hi engineer,
     I used the BF609 TM0_TMR3 pin to receive the square wave which is created by  AC singal with realtime frequency variation. I want to use the "TIMER Width Capture(WIDCAP) Mode" to caculate the realtime frequency about the singal.
     Certainly, I use the CCES1.0.2.0 to write programs running on Core1 and the another Core0 running the Linux OS.
The following is my part code written by CCES:
add the following code to pinmux_config.c file:
/* PORTx_MUX registers */
    *pREG_PORTG_MUX = TIMER0_TMR3_PORTG_MUX;
    /* PORTx_FER registers */
    *pREG_PORTG_FER = TIMER0_TMR3_PORTG_FER;
add the following code to main function:
uint8_t TimerMemory[ADI_TMR_MEMORY];
static void TimerHandler(void *pCBParam, uint32_t Event, void *pArg);
static ADI_TMR_HANDLE ghTimer;
static volatile bool gbTimerInt = false;
   adi_tmr_GetPeriod(ghTimer,&freqcount);
   adi_tmr_Enable(ghTimer, false);
   gbTimerInt = true;
void main(int argc, char *argv[])
eTmrResult=adi_tmr_Open(3,TimerMemory,ADI_TMR_MEMORY,TimerHandler,0,&ghTimer);
adi_tmr_SetMode(ghTimer, ADI_TMR_MODE_CAPTURE_DEASSERT);
eTmrResult |= adi_tmr_EnableGracefulStop(ghTimer, true);
eTmrResult |= adi_tmr_SetPulsePolarity(ghTimer, true);
eTmrResult |= adi_tmr_SetClkInSource(ghTimer, ADI_TMR_CLKIN_ALTCLK0);
while(1)
  while(gbTimerInt== true);
             gbTimerInt = false;
             adi_tmr_Enable(ghTimer,true);
I can not get value from freqcount by "adi_tmr_GetPeriod(ghTimer,&freqcount);"
Hope to hear your guidance ASAP!
Happy New Year!
Thanks & Best Regards!
