ADIS16229 used in Steel Plant for Vibration Monitoring
Question asked by starraytheon on Feb 25, 2015
Latest reply on Feb 25, 2015 by NevadaMark
Hi Experts,
I have a question in ADIS16229 application. I think the ADIS16229 is a very good device used in vibration monitor.
Do we have real application example used in Steel Plant field?
Because the Steel Plant has high temperature, the environment is very harsh.
BTW, the Steel Plant has Electromagnetic Shielding issue, will cause the RF signal transmitted not well.
Such as, in Gear Box, Shaft inner space, this kind application, the sensor need to be set in the capsule.
If the RF transceiver is not OK, the mature design used in the industrial, is it wired current loop or other solution?
Otherwise, Can you share me related papers used in harsh environment, for MEMS Acc and IMU.
Thanks a lot!
Yours Sincerely,
Tom Qi
