Boot issue on a BF548 Ez-Kit board
Question asked by MikeSmithCanada on Nov 15, 2010
Latest reply on Nov 17, 2010 by MikeSmithCanada
Hi
Am having a bad day -- can you point out where I might be going wrong
I have a project -- using 548 LCD screen -- build the project -- runs okay
I have settings using LDF with -- access external memory
and options using external memory
I then switch over to generating a loader
    QUESTION 1
    I presume I need a 16 bit width build
I then disconnect VDSP from the board, power down and power up
Reconnect VDSP and go and access the 548 loader
     I load the driver and load my ldr
    QUESTION 2
    I presume that there is only one driver, so that I can't make a mistake there
I then program the flash
     There are a number of large images that are hard coded so this takes a long time
I then disconnect from VDSP -- remove the JTAG and power down and power up
Not working is something I could handle -- but being totally ignored by the 548 is to much for my shattered ego
Iwas totally ignored, with the system booting up into the standard power up test showing  the 3 blackfin images
Any suggestions to solve my mistake would be apprecaited
Question 3 -- it is an older 548 board -- does that have any impact
Thanks
Mike Smith
