HDMI signal coming out from ADV7511KSTZ-P on a custom board is identified only on one TV set ( LG-M2252 ) and is not identified on any other TV sets.
Question asked by Aphraton on Feb 18, 2015
Latest reply on Feb 19, 2015 by GuenterL
Hello!
Please let me know - what could be the typical problem that HDMI signal coming out from ADV7511KSTZ-P on a custom board is identified only on one TV set ( on LG-M2252 it is perfect and stable) and is not identified ( no picture at all ) on any other TV sets?
In this test mode the input to ADV7511KSTZ-P ( both 20-bit Video data stream and SPDIF ) is coming from ADV7612BSWZ-P via FPGA.
Both parts are set to 1080i50 / 20 bit / 422 / Embedded Syncs mode.
Length of connection cables does't matter.
Both parts are initialized as recommended in this forum ( see below ).
How do You think - this problem most likely is caused by what?
1). signal integrity problems
2). wrong ADV7511KSTZ-P and  ADV7612BSWZ-P register setting
3). wrong setup / hold times for 20-bit Video data stream / SPDIF that come ADV7612BSWZ-P from  to ADV7511KSTZ-P
Ironically, LG-M2252 was the only TV set on which this custom board was tested and I thought, that all was OK until I tried other TV sets (((
Please give me at least a hint!
Here is how ADV7511KSTZ-P and  ADV7612BSWZ-P are initialized.
;ADV7612
> $98 $FF $80 ; I2C Reset
> $98 $FD $44 ; CP
> $98 $FA $6C ; EDID
> $98 $F9 $64 ; KSV
> $98 $FB $68 ; HDMI
> $98 $F8 $4C ; DPLL
> $98 $00 $14 ; VID_STD = 1080i
> $98 $01 $15 ; Prim_Mode =101b HDMI-COMP 50Hz
> $98 $02 $F5 ; CSC
> $98 $03 $81 ; 20 Bit ITU656 SDR Mode
> $98 $04 $60 ; OP_CH_SEL + 27MHz
> $98 $0B $44 ; Power up part
> $98 $0C $42 ; Power up part
> $98 $14 $7F ; Max Drive Strength
> $98 $15 $80 ; Disable tristate
> $98 $19 $83 ; LLC DLL phase
> $98 $33 $40 ; LLC DLL Enable
> $44 $BA $01 ; Set HDMI FreeRun
> $4C $B5 $02 ; MCLK=384x48kHz
> $64 $40 $81 ; Disable HDCP 1.1 features
> $68 $9B $03 ; ADI recommended setting
> $68 $00 $09 ; Set HDMI Input Port B (BG_MEAS_PORT_SEL = 001b)
> $68 $02 $03 ; Enable Ports A & B in background mode
> $68 $83 $FC ; Enable clock terminators for port A & B
> $68 $6F $0C ; ADI recommended setting
> $68 $85 $1F ; ADI recommended setting
> $68 $87 $70 ; ADI recommended setting
> $68 $8D $04 ; LFG Port A
> $68 $8E $1E ; HFG Port A
> $68 $1A $8A ; unmute audio
> $68 $57 $DA ; ADI recommended setting
> $68 $58 $01 ; ADI recommended setting
> $68 $75 $10 ; DDC drive strength
> $68 $90 $04 ; LFG Port B
> $68 $91 $1E ; HFG Port B
;ADV7511
> $72 $01 $00 ; Set N Value(6144)
> $72 $02 $18 ; Set N Value(6144)
> $72 $03 $00 ; Set N Value(6144)
> $72 $0A $11 ; SPDIF Select
> $72 $0B $8E ; SPDIF Enable
> $72 $0C $80 ; Disable all I2S
> $72 $15 $22 ; Input 422 (RGB or YCrCb) with Embedded Syncs, 48kHz fs
> $72 $16 $19 ; Output format 444, 30-bit input
> $72 $18 $C6 ; CSC disabled
> $72 $40 $80 ; General Control packet enable
> $72 $41 $10 ; Power down control
> $72 $48 $08 ; Data right justified
> $72 $49 $00 ; No truncation
> $72 $4C $05 ; 30bit/pix Output
> $72 $55 $40 ; Set YCrCb 444 in AVinfo Frame
> $72 $56 $08 ; Set active format Aspect
> $72 $96 $20 ; HPD Interrupt clear
> $72 $D6 $C0 ; HPD Interrupt clear ; HPD is always high
> $72 $98 $03 ; ADI Recommended Write
> $72 $99 $02 ; ADI Recommended Write
> $72 $9A $E0 ; ADI Recommended Write
> $72 $9C $30 ; PLL Filter R1 Value  /  ADI Recommended Write
> $72 $9D $61 ; Set clock divide
> $72 $A2 $A4 ; ADI Recommended Write
> $72 $A3 $A4 ; ADI Recommended Write
> $72 $A5 $04 ; ADI Recommended Write
> $72 $AB $40 ; ADI Recommended Write
> $72 $AF $16 ; Set HDMI Mode
> $72 $BA $60 ; No clock delay
> $72 $D1 $FF ; ADI Recommended Write
> $72 $DE $D8 ; ADI Recommended Write
> $72 $E4 $60 ; VCO_Swing_Reference_Voltage  /  ADI Recommended Write
> $72 $E0 $D0 ;
> $72 $F9 $00 ;
;; Enable 7511 sync regenerators
;; reference Table 33,34,35
> $72 $30 $84 ; $84 for 50Hz  $16 for 60Hz
> $72 $31 $02
> $72 $32 $C0
> $72 $33 $10
> $72 $34 $05
> $72 $35 $2F
> $72 $36 $E9
> $72 $37 $0F
> $72 $38 $00
> $72 $39 $43
> $72 $3A $80
> $72 $D7 $84 ; $84 for 50Hz  $16 for 60Hz
> $72 $D8 $02
> $72 $D9 $C0
> $72 $DA $10
> $72 $DB $05
> $72 $DC $00
> $72 $DD $00
> $72 $FA $00
> $72 $FB $00
