ADV7619 support....
Question asked by pjxan Employee on Feb 17, 2015
Latest reply on Feb 18, 2015 by mattp
Hi !
I've a customer that need support/comment on their use of the ADV7619 :
What is the correct ADV7619 configuration to achieve the following behavior?
Source:
4k2k (29,97fps) YCbCr 4:2:2, 8bit/component, TMDS =
297MHz.
Output:
2x16 SDR, YCbCr 4:2:2,  LCC = 148,5Mhz.
The datasheets state that “2 x SDR 4:2:2 Interleaved mode 0” is not available when CP is bypassed, but for HDMI formats over 2.25Gbps the CP must be bypassed and 2x24 pass-through (interleaved?) should be used.
In the example scripts for configuring 4k2k the CP is not bypassed.
Looking at the example scripts for 4k2k, the following script has been constructed. The changed commands are marked with ----><----.
:03-02 4K2K YCbCr 422 In - 2x16-bit YCbCr 422 Out:
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
68 C0 03 ; ADI Required Write
98 01 06 ; Prim_Mode =110b HDMI-GR (101b for HDMI-comp?)
98 02 F0 ; Auto CSC, YCbCr out, Set op_656 bit
---->98 03 94 ; 2x16 bit SDR 422 interleaved mode
0<----
98 05 28 ; AV Codes Off
98 06 A0 ; No inversion on VS,HS pins
98 0C 42 ; Power up part
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL MUX enable
98 DD A0 ; LLC Half frequency
4C B5 01 ; Setting MCLK to 256Fs
4C C3 80 ; ADI Required Write
4C CF 03 ; ADI Required Write
68 C0 03 ; ADI Required write
---->68 00 09 ; Set HDMI Input Port B (BG_MEAS_PORT_SEL
= 001b)<----
68 02 03 ; ALL BG Ports enabled
68 03 98 ; ADI Required Write
68 10 A5 ; ADI Required Write
68 1B 00 ; ADI Required Write
68 45 04 ; ADI Required Write
68 97 C0 ; ADI Required Write
68 3E 69 ; ADI Required Write
68 3F 46 ; ADI Required Write
68 4E FE ; ADI Required Write
68 4F 08 ; ADI Required Write
68 50 00 ; ADI Required Write
68 57 A3 ; ADI Required Write
68 58 07 ; ADI Required Write
68 6F 08 ; ADI Required Write
68 83 FC ; Enable clock terminators for port A & B
68 84 03 ; FP MODE
68 85 10 ; ADI Required Write
68 86 9B ; ADI Required Write
68 89 03 ; HF Gain
68 9B 03 ; ADI Required Write
68 93 03 ; ADI Required Write
68 5A 80 ; ADI Required Write
68 9C 80 ; ADI Required Write
68 9C C0 ; ADI Required Write
68 9C 00 ; ADI Required Write
End
Does this configuration look correct to you?
BR Patrik
