Can HMC698LP5 use differential LVPECL for REF?
Question asked by Kevin.G Employee on Feb 10, 2015
Latest reply on Feb 11, 2015 by MRichardson
The typical application circuit and evaluation circuit only show NREF bypassed to ground with a single-ended signal being ac-coupled into REF.  Will the HMC698LP5 work with a differential input into both REF and NREF?  If so, can the differential input be LVPECL or HCMOS?
I suspect that a differential square wave input is fine, but the logic levels I want to use may not be.  The only datasheet spec for the REF input is an amplitude of +/-5dBm min & max at 100MHz.  According to http://designtools.analog.com/dt/dbconvert/dbconvert.html a +/-5dBm square wave is about 0.25Vp-p to 0.8Vp-p.  Am I right about this?
