Help with ADC data stream from PL to PS. Whats wrong with this design?
Question asked by Shan.sk on Feb 9, 2015
Latest reply on Feb 11, 2015 by CsomI
I'm trying to connect the AD7961 (5MHz) I designed tADC to Zedboard. I got the AD7961 no-os driver module from the AD7961 example project at AD-WIKI site which has the following interface:
module AD7961
        input           m_clk_i,                    // 100 MHz Clock, used for tiing
        input           fast_clk_i,                 // Maximum 300 MHz Clock, used for serial transfer
        input           reset_n_i,                  // Reset signal, active low
        input   [ 3:0]  en_i,                       // Enable pins input
        input           d_pos_i,                    // Data In, Positive Pair
        input           d_neg_i,                    // Data In, Negative Pair
        input           dco_pos_i,                  // Echoed Clock In, Positive Pair
        input           dco_neg_i,                  // Echoed Clock In, Negative Pair
        output  [ 3:0]  en_o,                       // Enable pins output
        output          cnv_pos_o,                  // Convert Out, Positive Pair
        output          cnv_neg_o,                  // Convert Out, Negative Pair
        output          clk_pos_o,                  // Clock Out, Positive Pair
        output          clk_neg_o,                  // Clock Out, Negative Pair
        output          data_rd_rdy_o,              // Signals that new data is available
        output  [15:0]  data_o                      // Read Data
I designed custom IP using AXI4Stream interface and in the default code I replaced the commented line with the assignment to adc_data_reg which gets the value of adc_data_out wire from the ad7961 module.
// Streaming output data is read from FIFO
     always @( posedge M_AXIS_ACLK )
     begin
       if(!M_AXIS_ARESETN)
         begin
           stream_data_out <= 1;
         end
       else if (tx_en)// && M_AXIS_TSTRB[byte_index]
         begin
          // stream_data_out <= read_pointer + 32'b1;
          stream_data_out <= adc_data_reg;
         end
     end
And here's my block design:
I used the data_rd_rdy_out as a clock for the m00_axis and the fifo input. In the SDK I used the DMA to collect data in the DDR but when I check that data its not correct. Whats wrong with this design?
Could you please help me out?
Thanks.
Shan
