recommended method to version control hdl proj originating from github
Question asked by AnhDat on Feb 5, 2015
Latest reply on Feb 5, 2015 by AnhDat
How do you purpose I version control a subset of the below code provided that I will be adding blocks to, etc:
https://github.com/analogdevicesinc/hdl/tree/hdl_2014_r2
* you have many tcl scripts which are used to generate their custom IPs I guess first from their libraries and then the specific project, in my case the hdl/projects/fmcomms2/vc707/ branch
* you run your builds in project mode, but I like using non-project mode
* you recommend to use vivado 2014.2 which I do currently, but when I set up my Make system and version control I'd like to make it flexible so I could regenerate the cores easily for a later vivado version if needed
I've been playing with a few ideas:
1- take your working project after running all their tcl scripts, copy out all IP .xci files, and then version control those and use "read_ip" for those in non-project mode.  (I wouldn't have to track the individual .xdc constraint files per IP in this case right?)
2- I wanted to maybe be able to use "write_bd_tcl"  and then source this out putted tcl file in my non-project mode, but I am missing their analog.com vendor IPs it looks like when it goes to source the written bd tcl, and errors out
3- I thought maybe I'd take their system.bd file and just do a "read_bd" to load up all the IP blocks, but that doesn't seem to work...
I've been looking through documents such as:
http://forums.xilinx.com/t5/Vivado-TCL-Community/IP-Integrator-in-non-project-flow/td-p/320467
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug892-vivado-design-flows-overview.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug896-vivado-ip.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug994-vivado-ip-subsystems.pdf
http://www.xilinx.com/training/vivado/using-the-non-project-batch-flow.htm
http://www.xilinx.com/support/answers/55692.html
Let me know what route in your opinion is best to go ... THANKS!
